Registration is FREE!
There are over 8,700 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, post new topics or reply to others, communicate privately with other members, respond to polls, upload content and access many other special features.
Old 11-19-2008, 04:22 PM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is offline
Gas meter access.
Remodeled home today, rear porch was extended over the gas meter. The access panel opening is less than 22" by 24" (UPC 1209.5) probably not relavent but IRC has nothing I could find.
The 2006 N.C. Fuel Gas Code 401.9 states
"Accessible and Acceptable Location
A meter location, when required, shall be provided for the building or premises to be served. Gas metes shall be readily accessivle for inspection, reading, and replacement. Location, space requirements, dimensions, and type of installation shall be acceptable to the gas company."
(Code man speak with forked tongue)
What do I put in the report? "Recommend letter of acceptable installation be obtained from the gas co. prior to cllosing."?
Thoughts......anyone!
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Old 11-19-2008, 04:37 PM
Scott Patterson's Avatar
Re: Gas meter access.
What do I put in the report? "Recommend letter of acceptable installation be obtained from the gas co. prior to closing."?
The utility company has the final say in the matter.
You could report it just like you wrote. One thing however, I doubt they will get a letter from anyone saying it is OK. Might be best to simply tell them it is under the deck and that they should check with the gas company to see if that location is OK.
Scott Patterson
Old 11-19-2008, 04:44 PM
mitch buchanan mitch buchanan is offline
Vern,
Your verbige sounds good to me to protect your buyer and you. Here in KY, the gas company is king - they can come into an existing home that met all gas, etc. codes when built (even fairly new ones -less than 10 years old) and after a meter upgrade, demand venting changes or they red tag/turn off gas! That happened to a client of mine, and I had to explain how the gas appliance was code approved in the past (inspection tag on water heater), codes changed later and she had to do what they said. Needless to say, she wasn't happy and somehow it was my fault! Oh well...
Old 11-19-2008, 04:57 PM
Rick Hurst's Avatar
That meter location would not be acceptable in our area. The meter has to be accessible to the service person. They would not be lifting any decking material to be able to read the meter or to turn off / on the service.
I'd probably say that seller built that deck right over the meter without making a single call to the gas provider.
Old 11-19-2008, 05:13 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Utility Company may be King ( But I find it hard to believe they were Consulted Before this Porch was Erected Over The Gas Meter.)
see page 3 of attachment for 6 feet requirement for overhang ( does not even meet 3 feet to electrical outlet.)
Billy J. Stephens HI Service
  #6 (permalink)
Old 11-19-2008, 05:33 PM
How and who is reading the meter?
Scott Patterson
  #7 (permalink)
Old 11-19-2008, 05:34 PM
Thanks for the input.
  #8 (permalink)
Old 11-19-2008, 05:37 PM
Quote:
Most all of the water, gas & electric is read by radio signal from the meter to a meter reader driving down the street. They seldom go to the meter anymore.
  #9 (permalink)
Old 11-19-2008, 05:58 PM
Jerry Peck's Avatar
You should not care how hard it is to get that letter, and if the gas company is not willing to provide that letter, then their verbal okay is not going to hold any weight should anything happen.
Recommend they get the letter. It will protect your client and you.
The gas company will not be able to say 'We did not know it was THERE.'
  #10 (permalink)
Old 11-19-2008, 06:36 PM
That was my thought as well. I really don't think they know about it!
Thanks Jerry.
  #11 (permalink)
Old 11-19-2008, 07:33 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is online now
Quote:
Ya right! If his gas company is as bad as ours (NIPSCO), they tell the client what is wrong but wont put anything in writing. Then the new homeowner is upset because he doesn't understand everything the gas guy told him. Nice customer service.
  #12 (permalink)
Old 11-19-2008, 07:40 PM
Kevin Luce's Avatar
Where else can that information be found? I looked in the International Gas Fuel Code book and I can't find anything that talks about the 3 foot clearance requirement. The local gas company enforces it but I cannot find where they get this information. It has to be available to the contractors or how else are they suppose to understand what is and is not allowed. Note: Most heating companies don't know about any clearance requirement.
  #13 (permalink)
Old 11-19-2008, 08:09 PM
Jerry Peck's Avatar
Quote:
Precisely.
And, by NOT issuing a letter stating that is it okay, that means IT IS *NOT* okay.
Which means: Correct it.
This is not rocket science stuff, guys.
If the utility company DOES NOT issue the letter stating it is correct, then it is NOT correct. As simple as that. When an agent, seller, whomever tries to disagree and say it is correct, all that needs to be said is: "The utility company REFUSED to say it was correct. If it is NOT CORRECT, then it is INCORRECT. FIX IT.
  #14 (permalink)
Old 11-19-2008, 08:13 PM
Jerry Peck's Avatar
Here is one from Puget Sound Energy.
I believe those clearances are in NFPA 58.
  #15 (permalink)
Old 11-20-2008, 05:37 AM
Jim Zborowski Jim Zborowski is offline
One other consideration is that in case of emergency ( fire ) the fire dept. would have to search for the meter to turn it off, thereby wasting valuable time.
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Similar Threads
Attic Access Jim Robinson General Chit Chat: Home Inspectors & Commercial Inspectors 6 03-08-2008 03:26 PM
Attic access problems Brian E Kelly Attic Areas: Home Inspection and Commercial Inspection 30 12-22-2007 05:28 AM
Attic Access Hatches Erol Kartal Attic Areas: Home Inspection and Commercial Inspection 13 08-15-2007 07:46 AM
Attic Access Requirements dan orourke Attic Areas: Home Inspection and Commercial Inspection 2 07-14-2007 07:18 PM
Furance Access. Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 05-02-2007 02:57 PM
vB.Sponsors
Ad Management by RedTyger
