Old 05-16-2007, 09:42 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Poor Cat
Can't have a BM without the possibility of getting scalded to death.
Redneck emergency drain pan maybe?
Old 05-16-2007, 10:58 PM
Thom Walker's Avatar
Re: Poor Cat
I never thought about it until I saw your picture. Will a TPR valve work the same no matter what its orientation? Obviously a bad one will leak no matter what its position, but will it function as intended and will its service life remain the same?
- Paul Fix
Old 05-17-2007, 02:20 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: Poor Cat
That shouldn't be a TPR valve. It may just be a pressure relief valve. TPR should be installed into the water heater tank. I'm sure the valves would work no matter the orientation, but it would be hard for the valve to drain down hill all of the way if it was starting out upside down.
Old 05-17-2007, 02:25 PM
Re: Poor Cat
Sure looks like a TPR.
- Paul Fix
Old 05-17-2007, 04:28 PM
Richard Rushing's Avatar
Re: Poor Cat
That is a TPR.
That damn cat should be tied up and held in place under that sucker...
I can't stand a damn animal that will make a public desplay of licking their own arse then hawk-up a hair-ball!!! Well, duh!
I still like using them for garage door testing...
RR
Richard Rushing, HCRI
Duncanville, Tx.
  #6 (permalink)
Old 05-17-2007, 04:38 PM
Re: Poor Cat
It is a T&P, it should be a pressure relief only.
Unless that is the only T&P, in which case it is in the wrong place and will not work as designed or intended.
Home inspection
Similar Threads
Poor Man's Solar Collector Bruce Breedlove Roofing System: Home Inspection and Commercial Inspection 1 04-05-2007 11:52 AM
vB.Sponsors
Ad Management by RedTyger
