Old 05-17-2007, 09:32 AM
wayne soper's Avatar
condensate pump drainage
Why would you want to stick a consensate drain line into the waste line for the toilet above? Any codes here besides the stupid contractor code?Anyone seen this before?
Old 05-17-2007, 11:57 AM
David Banks David Banks is offline
Re: condensate pump drainage
Not allowed. Done because it is quick and dirty.
Code Check says.
No direct connection to waste or vent pipe.
No drilling(sattle fitting) of DWV pipes to accept condensate drain.
May drain to indirect receptor(Lav,tailpiece,tub overflow) UMC only.
Dave
Old 05-17-2007, 02:49 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Great picture. Keep that one for the scrap book. I have never seen that before.
Old 05-17-2007, 04:35 PM
As the others have said, not allowed - it requires an air gap / indirect connection, and not there.
Wonder how much crap came out onto them when they drilled that hole?
That should have been a clue?
Maybe 'that's their sign'?
Old 03-10-2008, 05:10 PM
Dennis Corbett Dennis Corbett is offline
Because of capacity problems at both of our city's water and sewage treatment plants and the nasty properties of condensate, the discharge is required to be retained on the property. We also have expansive soils, so you need to dig a drywell, 2' by 2' by 2' and a minimum 3' from foundation, filled with 1 1/2" drain rock, covered by plastic and 6" of soil. 1 1/2" ABS or PVC to carry the discharge from an airbreak at the building to drywell.
  #6 (permalink)
Old 03-10-2008, 07:08 PM
Joshua Hardesty Joshua Hardesty is offline
I'd also be a bit concerned by the apparently notched double, and the short 90 used on a verticle to horizontal transition.
Similar Threads
Sewage ejection pump-GFCI? Mike Huppi Electrical Systems: Home Inspection and Commercial Inspection 13 06-23-2007 10:50 PM
Loud gurlging noises - sink/tub drainage John Stephenson Plumbing System: Home Inspection and Commercial Inspection 5 05-16-2007 08:57 PM
Heat Pump? David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 01:04 PM
condensate drain routing Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-16-2007 07:49 PM
condensate drain connection dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 04-12-2007 08:19 PM
vB.Sponsors
Ad Management by RedTyger
