Old 05-21-2007, 02:53 PM
David Banks David Banks is offline
Dishwasher
Homeowner special. Dishwasher away from sink so the hooked up feed and drain directly through floor into basement.
Any good writeup suggestions. Is there a siphon issue with no high loop?
Feed line has no shutoff and dubious connection.
Dave
Old 05-21-2007, 04:03 PM
Gunnar Alquist's Avatar
Re: Dishwasher
David,
If memory serves, no p-trap allowed below floor level (except tub/shower). I think you mentioned no airgap.
What is the circumference of a moose?
Old 05-21-2007, 05:47 PM
Re: Dishwasher
No vent - that's a big problem.
No air gap, either into a disposal, air gap, or into a tailpiece fitting, all of which allows for an atmospheric break between the water being pumped out and the drain gravity draining away.
There is a potential for cross connection.
Accessibility of the trap could be a problem.
There is a minimum/maximum fall distance to the trap, but everything is screwed up, so that cannot even be measured.
Those should serve as good starting points.
Old 05-21-2007, 06:51 PM
Re: Dishwasher
Thanks Jerry that helps a lot. Plumbing not one of my strong points.
Dave
Similar Threads
GE dishwasher recall John Arnold Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 05-16-2007 03:55 PM
vB.Sponsors
Ad Management by RedTyger
