Old 05-23-2007, 06:55 AM
Greg Jenkins Greg Jenkins is offline
Type of gas pipe
What type of gas piping is this? I am not familiar with it. It appears to be aluminum or stainless. What are its limitations and installation requirements? It was only serving a gas fireplace insert (gas logs).
Thanks - Greg
Greg Jenkins
Old 05-23-2007, 07:54 AM
Bob Harper's Avatar
Re: Type of gas pipe
Swagelok Products including Fittings, Valves, Tubing, Gauges, Modular Systems, Alternative Fuels, Sanitary, Plastic Products
Appears to be Swagelok, which is approved for gas. While this fitting is approved for both aluminum and stainless (and copper). However aluminum is Not approved except inside fireplaces and similar connectors.
Expensive fittings
Old 05-23-2007, 08:37 AM
John Arnold John Arnold is online now
Bob - Could you re-phrase? I'm confused by your post.
Illegal aliens have always been a problem in the United States. Ask any Indian. -Robert Orben, magician and author (b. 1927) / www.ArnoldHomeInspections.com
Old 05-23-2007, 04:39 PM
Bob Harper's Avatar
Don't feel alone John, I confuse myself all the time!
What I was getting at is to look at the fitting and the tubing separately. Swagelok is a tube fitting that is generally approved for copper, stainless steel, aluminum, PE, etc. tubing for all sorts of applications from fuel gas to heating oil to corrosive industrial compounds to medical gases to all sorts of stuff. One common application is on anodeless risers on PE tubing coming from the street out of the ground up to a meter.
IFGC 403.4.4 deals with aluminum. Aside from all the other caveats for this tubing, it states," Aluminum-alloy pipe shall not be used in exterior locations or underground." It also must be "coated to protect against external corrosion where it is in contact with masonry, plater or insulation or is subject to repeated wettings by liquids such as water, detergents, or sewage."
The Commentary reads:"Aluminum pipe is not commonly used for gas service. Because aluminum is a fairly reactive metal, it corrodes readily when exposed to a variety of materials and the environment."
Even stainless steel has its limits and depends a lot on the alloy.
Does this clarify things any?
Old 05-23-2007, 06:28 PM
Thanks Bob. So, in a roundabout way, you answered Greg's question ("What kind of gas piping is this?". The answer is, it's aluminum, and shouldn't be used outside like that. Right?
Plus you gave a ton of other useful info, as usual.
I'm easily confused.
  #6 (permalink)
Old 05-23-2007, 06:57 PM
Thanks for your input Bob and John - it was a big help.
Greg Jenkins
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Similar Threads
New type of cricket Paul Kondzich Roofing System: Home Inspection and Commercial Inspection 2 05-11-2007 07:48 AM
Roof Type David Banks Roofing System: Home Inspection and Commercial Inspection 5 05-01-2007 05:49 AM
Flue pipe wayne soper Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 10 04-21-2007 06:32 PM
Fastener type for flashing dan orourke Roofing System: Home Inspection and Commercial Inspection 10 04-19-2007 03:51 AM
Insulation type Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 6 04-07-2007 09:47 AM
vB.Sponsors
Ad Management by RedTyger
