Old 02-25-2009, 05:09 PM
Tim Kallmer Tim Kallmer is offline
What type of water piping is this?
I ran across this pipe with which I am not familiar. The pipe material appeared semi-translucent. There were no markings present. It did not seem to be PEX or CPVC. It could be seen only at the water heater at the cold and hot lines, as well as the circulating line. There was a brass elbow fitting visible near the circulating pump. The elbow was quite abrupt--a very small radius turn. It had rings around the connections to the pipe, but they didn't seem to be crimp connections. Does anyone know what this is and if it is approved for water piping use?
Old 02-25-2009, 05:29 PM
Jerry Peck's Avatar
Re: What type of water piping is this?
It looks like it may be one of the types of PEX with connections which are expanded and contracted back down over the fitting, not enough of the pipe in the photo to know for sure or not.
Most PEX installation use metal crimp rings, there are one (or more?) other system(s) out there for connecting PEX to the fittings.
Old 02-25-2009, 05:35 PM
Jerry Peck's Avatar
Go here: Uponor - For Professionals
Scroll down to 'Plumbing Submittals', then down to, and click on, 'ProPEX Fittings', then click on the link to the right of '2 inch Wirsbo AQUAPEX Expansion Joint Kit' ---- http://www.uponor-usa.com/~/media/Files/Technical%20Documents/Specifications%20and%20Submittals/Plumbing/AQUAPEX%20Tubing/2%20inch%20Wirsbo%20AQUAPEX%20Expansion%20Joint%20 Kit.aspx?sc_lang=en
That's the stuff I'm thinking it is, and it looks real close to your photo too.
Old 02-25-2009, 06:31 PM
I believe you are right--that certainly looks like it. And they do offer brass fittings. I had not seen that type of PEX product before.
Thanks again. I appreciate the quick reply!
Old 02-26-2009, 01:15 PM
James Foy James Foy is offline
Looks like PEX. Wirsbo (which just changed their name) has fittings that use a special tool to expand them at connections, which then contract to give a water-tight connection.
  #6 (permalink)
Old 02-26-2009, 02:10 PM
Scott Patterson's Avatar
That is a Wirsob (now Uponor) fitting.
Now, did anyone get a second set of pictures when they closed out the picture from Tim? I got a little set of photos of scantly clad and unclad young ladies when I closed out the picture. I might have clicked on the top banner, anyway be careful with those free photo albums.
Scott Patterson
Similar Threads
PEX piping Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 1 08-26-2008 06:12 PM
PVC Supply piping fritzkelly Plumbing System: Home Inspection and Commercial Inspection 5 02-26-2008 01:44 PM
ABS Piping allen elliott Plumbing System: Home Inspection and Commercial Inspection 4 02-26-2008 10:36 AM
galvanized piping Scott Lynch Plumbing System: Home Inspection and Commercial Inspection 5 07-22-2007 07:36 PM
Unknown piping. Eric Shuman Plumbing System: Home Inspection and Commercial Inspection 11 05-14-2007 08:09 PM
vB.Sponsors
Ad Management by RedTyger
