05-24-2007, 07:51 AM
Extra discharge pipe
I came across an extra section of pipe attached to the main plastic discharge line, and I have no idea what it's for. It's capped on the end as shown in the photos. Any ideas?
Scott Dana
Dana Home Inspections, Inc.
05-24-2007, 07:52 AM
Re: Extra discharge pipe
working on a better photo
Scott Dana
05-24-2007, 08:02 AM
Better (hopefully) photo attached.
Scott Dana
05-24-2007, 08:23 AM
Scott
Just a guess, but may have been planned to be to sewage pump line. Decided to run a different line so pump would not have to pump as high.
But again, just a guess.
I think it should be removed, could fill with water, extra weight could it break off.
Rick Cantrell
05-24-2007, 08:33 AM
My guess is a line that was run for a vent. Where does the other end of the pipe terminate?
05-24-2007, 08:36 AM
If you can see the red arrows I drew, the line terminates with a cap Also, there was a vent line coming from the sanitary pump that is not visible.
Scott Dana
05-24-2007, 09:06 AM
The connections are wrong and where's the vent piping?
Perhaps they abandoned what would appear to be a bad installation?
05-24-2007, 10:14 AM
Does it go through the roof, or at least into the attic? I know this is not likely, but could it be for a later installation of radon mitigation? It looks like it might be the right size.
- BOB
05-24-2007, 10:31 AM
a sanitary t used in a vertical to horizontal drain line connection is wrong exception is if it is used as a vent.
05-24-2007, 06:56 PM
Regardless, it goes vertically down into a horizontal line through a sanitary tee.
Sanitary tees are approved for use from horizontal into vertical - P3005.1 and Table P3005.1, IRC.
Plus, you wrote up that exposed facing on the insulation, right?
05-25-2007, 04:55 AM
I'm thinking based on some comments, that it was a first attempt at connecting to the sanitary pump. And the pump did have a vent pipe that is not visible, separate from all the visible pipe in the photo.
I did not write up the insulation issue...I guess I was too enthralled with the pipe :0
Scott Dana
05-25-2007, 08:27 AM
what is wrong with exposed facing in an underfloor area?
05-25-2007, 02:44 PM
Brian,
There is an area on *each* batt which states something like this:
WARNING: RISK OF FIRE! DO NOT LEAVE THIS FACING EXPOSED! The facing must be in contact with approved building materials.
There are variations of the wording, but you get the idea.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Type of gas pipe |
Greg Jenkins |
5 |
05-23-2007 05:57 PM |
| Condensation On Flue Pipe |
Jim Robinson |
6 |
04-29-2007 10:18 AM |
| Flue pipe |
wayne soper |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
10 |
04-21-2007 05:32 PM |
| vertical pipe on relief line |
wes owens |
12 |
04-18-2007 07:30 PM |
| ABS Flue Pipe on LP Water Heater |
Trey Humphreys |
6 |
04-03-2007 01:11 PM |
