Old 05-29-2007, 05:57 PM
Eric Laney Eric Laney is offline
Gas supply line tap
Saw this today. Just past gas meter they added a 3/8 line with one of those valves like on a freon can. Can't be legal right? It was for a gas grill.
Old 05-29-2007, 06:04 PM
Re: Gas supply line tap
Quote:
Correct.
Old 05-29-2007, 07:54 PM
Richard Rushing's Avatar
Dude.... those quick connects sometimes hang in the open position!! The is a no-no.
Is that a painted copper line tapped off the main service line?
Rich
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-29-2007, 08:26 PM
Hmmmm ... I wonder if they turned the gas off when they drilled that hole in the steel pipe with a steel bit? Hmmmmm ...
Nah. Anyone smart enough to think of that would not do that anyway.
Old 05-29-2007, 09:47 PM
Bob Harper's Avatar
yeah, and where did those metal shavings go?
How about that illegal bushing?
Compression fitting?
Unprotected copper?
yes, illegal fitting. Not listed in the gas codes as an approved fitting. Just because it works for water doesn't make it ok for gas.
  #6 (permalink)
Old 05-30-2007, 03:22 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
All they need to go along with that riggin' is a set of these. Let the games begin!
Residential-Commercial-Construction-EIFS-Infrared Thermography
Similar Threads
Supply Air Vent? Rick Hurst Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 05-15-2007 07:27 AM
Gas Line Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 4 04-19-2007 10:51 PM
black flex gas line dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 04-18-2007 06:21 AM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 08:56 AM
Copper Gas Line - RobertSmith Plumbing System: Home Inspection and Commercial Inspection 12 04-12-2007 11:03 AM
vB.Sponsors
Ad Management by RedTyger
