Old 06-01-2007, 08:42 AM
Dishwasher drain line connection
Home inspection
Old 06-01-2007, 08:48 AM
Richard Rushing's Avatar
Re: Dishwasher drain line connection
See all the time with a hose clamp.
However, that drain line does not have a "high drain loop" as needed.
(see attachment).
Richard
Richard Rushing, HCRI
Duncanville, Tx.
Old 06-01-2007, 12:35 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Rich,
Nice diagram. Illinois in their infinite wisdom does not allow dishwashers to discharge into disposers. Concern is that the disposer could force waste back into the dishwasher.
Our dishwasher here at home has no loop AND runs into the disposer. I'm very defiant and will likely die a horrible and meaningless death as a result of dishwasher poisoning.
Eric Barker
Barrington, IL
Old 06-01-2007, 02:51 PM
Thom Walker's Avatar
It is tres gross when it happens; siphoning, not death.
- Paul Fix
Old 06-02-2007, 02:02 PM
Randy Aldering Randy Aldering is offline
Well, it appears that it has leaked before, so I would say no. The discharge line coupling is too large for the extension tube nipple. A rigid reducing coupling should be added, along with a smaller Fernco coupling, so that the coupling is properly sized for the extension tube nipple. The visible corrosion suggests that this fitting, as currently installed, weeps from time to time, and will eventually fail. If the nipple were to rot off the extension tube, and one were to cycle the dishwasher, it could get really interesting.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
Similar Threads
Equipment ground connection John Stephenson Electrical Systems: Home Inspection and Commercial Inspection 12 12-10-2007 01:25 PM
Dishwasher David Banks Plumbing System: Home Inspection and Commercial Inspection 3 05-21-2007 07:51 PM
GE dishwasher recall John Arnold Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 05-16-2007 04:55 PM
Primary drain line material John Stephenson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-10-2007 06:18 PM
condensate drain connection dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 04-12-2007 09:19 PM
vB.Sponsors
Ad Management by RedTyger
