Old 11-02-2009, 07:17 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
hot - cold reversed
Example: When you face a sink the hot should be on the left side and the cold on the right.
Consider a bathtub that has the fixtures mounted on the outer edge. In this configuration the fixtures are accessible from sitting in the tub or standing outside of it.
Which position do you adopt for determining which is the right or the left? From within the tub or from the outside?
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
HomeGauge Reports
Old 11-02-2009, 07:35 PM
Dan Harris Dan Harris is online now
Re: hot - cold reversed
That's a great question.
I do it from outside the tub.
I am guessing you will get answers about 50-50 each way
Phoenix AZ Home and Mobile Home Inspections.
www.inspectaz.com
Old 11-02-2009, 07:37 PM
Kevin Barre Kevin Barre is offline
It's as you face the spout. In your case, it would be from inside the tub.
Old 11-02-2009, 08:03 PM
Gunnar Alquist's Avatar
Example: When you face a sink the hot should be on the left side and the cold on the right. Consider a bathtub that has the fixtures mounted on the outer edge. In this configuration the fixtures are accessible from sitting in the tub or standing outside of it. Which position do you adopt for determining which is the right or the left? From within the tub or from the outside?
I refer from sitting in the tub and note it as such.
We have enough youth, how about a fountain of Smart?
Old 11-02-2009, 08:43 PM
Jerry Peck's Avatar
Quote:
Quote:
You address it from the users position - in the tub.
Note though, having the hot on the left *is not* a "code requirement", it is standard accepted practice and one which could result in burns if not followed ... and I would not want to the be defendant in that lawsuit.
Also, there are some imported (European) faucets which have hold and cold reversed as to the direction the handle turns, and as long as the permanent labeling/marking is correct they are allowed. At least I have found nothing which disallows them.
But again, *I* would not want to be the one listed as a defendant because someone got scalded from a "backward" faucet, even though the faucet was not actually "backward".
  #6 (permalink)
Old 11-03-2009, 04:57 AM
Rick Cantrell Rick Cantrell is offline
"Note though, having the hot on the left *is not* a "code requirement""
P2722.2 Hot water.
Fixture fittings and faucets that are supplied
with both hot and cold water shall be installed and
adjusted so that the left-hand side of thewater temperature control
represents the flow of hot water when facing the outlet.
Exception:
Shower and tub/shower mixing valves conforming
to ASSE 1016 or CSA B125, where the water temperature
control corresponds to the markings on the device.
Rick Cantrell
  #7 (permalink)
Old 11-03-2009, 05:41 AM
I've found them both ways in past inspections. I'll consider the judgement of the arrangement from within the tub from now on.
Thanks for the replies.
Similar Threads
Outlets in a 49 year old house(Hot Neutral Reversed) Sam Morris Electrical Systems: Home Inspection and Commercial Inspection 31 08-11-2009 02:36 PM
A new one on me, 2 ac systems reversed imported_John Smith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 13 07-21-2009 01:38 PM
it's cold out there John Arnold Plumbing System: Home Inspection and Commercial Inspection 2 01-21-2009 05:08 PM
reversed insulation? Jerome W. Young Attic Areas: Home Inspection and Commercial Inspection 2 01-16-2008 05:52 PM
Hot/Cold reversed - do you call it? Matt Fellman Plumbing System: Home Inspection and Commercial Inspection 14 12-07-2007 05:20 PM
vB.Sponsors
Ad Management by RedTyger
