Thanks Ron, I believe you would know judging by your knowledgeable replies here and on Terry's plumbing forum. I suspected it was incorrect info being passed on the net and not clarifying the residential restrictions that has been approved and in place, I believe, for a few years now.
I did not think of the City's position with regards to fires. So, it is a tough code city that still demands lead and oakum joints for commercial and mixed use or large residential buildings. BTW, our property has 3 inch copper from 2nd and 3rd floor condos coming down to the horizontal basement cast iron. It looks like pretty good work from previous plumbers. That copper must have been expensive even back 15 years ago ( still probably 2-3x less than what it is currently). I guess it was easier to work with than installing vertical stacks of 4" cast iron.
While I got your attention, a couple more questions please:
Is the cast iron pipe at Depot, the same as code or is it weaker thinner walled? Another plumber says it isn't as thick or code compliant but I question that. I had a feeling he was trying to profit on the materials.
I got a headache trying to go through the Chicago Plumbing code to try to find out if a Hair Salon say with 3 shampoo sinks (also used for color chemicals) requires special plumbing in Chicago? Do you have any experience or knowledge here or can you point me in the right direction? I think vacuum breakers are required on each one and I know there are pvc like hair traps for hair salon sinks, but I'm not sure these are to code in Chicago or if they must go to a cast iron hair trap? Also if it can drain afterwards into a 2 inch copper drain line from 2 kitchen sinks from 2 condos above the planned commercial space that then go through a grease trap and then into the main service city sewage line. Or must it enter the main separate and away from the condo kitchen sink lines?
Thanks a bunch Ron, we may need your services down the road if I can win another arm wrestle with my bank
- Mike
