Old 07-14-2007, 03:41 PM
Washer / Dryer Closet
Old 07-14-2007, 03:48 PM
Re: Washer / Dryer Closet
No limit in the codes that I know of, but the particular manuf. instructions might have something to say. I think it really just goes back to common sense.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 07-14-2007, 09:35 PM
David Banks David Banks is offline
Watch for combustion air requirements for gas dryer.
Dave
Old 07-14-2007, 09:39 PM
James Duffin James Duffin is offline
Since you can use stacked washer/dryers the room could be 30 inches...
Old 07-14-2007, 09:44 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Gas or electric, a clothes dryer will evacuate the area when in operation and needs appropriate makeup air provisions.
If all you have is a closet type niche for the washer/dryer, then you are going to want to see louvered doors in place.
  #6 (permalink)
Old 07-15-2007, 08:51 AM
No Code that I know of on makeup air, specific to dryers, except you aren't supposed to depressurize the living space. Since everything except the newer condensing dryers exhausts to outdoors, the air has to come from somewhere. Common sense tells you you have to provide the same amount of air on the input as you exhaust. Kind of like balancing you checkbook, you can't write more checks than you have deposits or bad things will happen.
Allen, Texas 75002
  #7 (permalink)
Old 07-15-2007, 09:03 AM
Richard Rushing's Avatar
Dan,
I don't think Philip was inferring that an electrical dryer needs make up air... Gas only.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
  #8 (permalink)
Old 07-15-2007, 10:14 AM
Dan,
There are two types of air a gas clothes dryer needs: 1) combustion air, 2) make up air as Jim described.
Electric clothes dryers do not (of course) need 1) combustion air. They do still need make up air for ventilation purposes.
Think of a clothes dryer as one high CFM exhaust fan running - needs replacement air from someplace.
  #9 (permalink)
Old 07-15-2007, 10:56 AM
Michael Thomas's Avatar
Dan,
Take a look here:
http://commerce.wi.gov/SBdocs/SB-UDC...yWorksheet.pdf
Similar Threads
Electrical service box located in closet Kevin Luce Electrical Systems: Home Inspection and Commercial Inspection 17 05-28-2008 08:40 PM
SE Panel In Close Closet OK K Robertson Electrical Systems: Home Inspection and Commercial Inspection 16 10-04-2007 01:28 PM
air ducts in closet dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 07-06-2007 01:15 PM
Gas Dryer in Bathroom David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 04-19-2007 10:54 PM
Water closet Mike Schulz Plumbing System: Home Inspection and Commercial Inspection 9 04-14-2007 03:49 PM
vB.Sponsors
Ad Management by RedTyger
