Old 07-14-2007, 06:05 PM
dan orourke dan orourke is offline
Water supply lines in attic
Old 07-14-2007, 06:57 PM
Re: Water supply lines in attic
Quote:
Originally Posted by dan orourke View Post
Is it a requirement for water heaters' water supply lines to be insulated?
Oklahoma City is shown as having a 13 degree design winter temperature degree day, which is less than 32 degrees.
Being as those lines are outside the thermal insulated envelope, yes, insulation (or heat - or both) is required.
Home inspection
Similar Threads
duct-tape on supply ducts wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 07-11-2007 03:47 PM
Cardboard supply ducts in slab Richard Moore Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 06-09-2007 08:22 AM
Gas supply line tap Eric Laney Plumbing System: Home Inspection and Commercial Inspection 5 05-30-2007 04:22 AM
Supply Air Vent? Rick Hurst Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 10 05-15-2007 08:27 AM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 09:56 AM
vB.Sponsors
Ad Management by RedTyger
