Old 07-16-2007, 08:13 PM
wayne soper's Avatar
wayne soper wayne soper is online now
Australian Vent pipe
This is how they do it down under. Yes there is a draft induction fan but. WOW FAns never break do they. I recommended turning the house over as usual.
Home inspection
Old 07-18-2007, 08:27 PM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
Re: Australian Vent pipe
Wayne, is this an oil water heater? If so, there is an 18" clearance off that chimney connector pipe. That means improper clearance to the foam insulation on the water pipes and the drywall and framing as well.
Also, chimneys and connectors are not designed or approved for positive flue gas pressure.
The downhill run is grossly improper, of course.
That barometric damper is not leveled and appears to be all taped up.
No screws used at joints. Foil tape not allowed.
No cleanout in chimney
Can this chimney serve both appliances at once? Those water heaters are generally high BTU/ GPH rates.
What is the condition of the chimney. Have a liner?
Any more pics?
Bob
Old 07-19-2007, 05:08 AM
Thanks BOB, Yeah I got all those things, along with CO readings while running the unit. I think the original unit was a shorter 30 gallon and they upgraded,
or downgraded in this case to a taller 50 gal. unit.
Client walked, broker blamed me, I blamed you and gave her all your numbers and info HAHAHA Thanks for the continued efforts. Wayne Soper
Similar Threads
Vent pipe wayne soper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-01-2007 05:39 PM
Flex vent pipe John Stephenson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 05-29-2007 09:57 AM
Foil tape on vent pipe Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 05-18-2007 04:12 PM
Upsized water heater vent pipe Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-30-2007 10:32 AM
Flue pipe wayne soper Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 10 04-21-2007 05:32 PM
vB.Sponsors
Ad Management by RedTyger
