Re: Odd ejector plumbing
Looks good to me except the line from the pump needs a check valve and a ball valve installed.
The discharge side of that is to the right (at least, that's the side with the check valve).
the lid doesn't looked sealed
Oh, it's sealed down real good, and I could not determine how. The lid is home-made and there didn't seem to be any fasteners - I suspect it's caulked down to the floor with adhesive caulk. Attic access was sealed up tight too - got an OK from the sellers to try to open it - worked on it for quite a while with the Stanley knife, but finally gave up when the plywood hatch cover started to delaminate before I could break it loose. Hopefully the sellers will get it off, and I'll be back there for a second look.
This was a Flip O' Rama, and there are a number of such home-brews (I thought the 25' garden-hose drain line from the island dishwahser to the laundery tub in the basement was pretty slick, myself)... lots of (I suspect) unpermited work - and I recommended the clients check with the building department.
Realtor was there when I gave the clients my "you could be on the hook for unpermited work by former owners" speech.
Afterwards, when the clients we driving off we talked a bit about the inspection.
Realtor said:
"While I was driving down I was taking to the listing broker, and she asked how it thought the inspection would go. I told here that I didn't have a particular reason, but the 'vibe' I got from this house was 'Unpermited Rehab by Son-In-Law'".
