Old 07-18-2007, 01:21 PM
gas shut off valve
Old 07-18-2007, 02:14 PM
Brian E Kelly Brian E Kelly is offline
Re: gas shut off valve
I am not sure of the code but a gas valve can not be easily turned and or damaged. What is the valve shutting off? I have never seen one in a cabinet.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 07-18-2007, 02:29 PM
John Arnold John Arnold is online now
I see the valves under cabinets where the gas hard pipe transitions to flex connector, usually for a gas counter unit. I tend to worry more about the flex connector getting banged around, but I don't believe it's against code.
Old 07-18-2007, 02:30 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
From the 2006 IRC...
"G2420.1.3 (409.1.3) Access to shutoff valves. Shutoff valves shall be located in places so as to provide access for operation and shall be installed so as to be protected from damage."
..."protected from damage" is a very general statement but I supposed you could make the argument that the valve could potentially be damaged by heavy stored items sharing the same space. You would, no doubt, get plenty of counter-arguments as well.
Old 07-18-2007, 03:02 PM
I think damage would be very unlikely inside a cabinet. I never call it. Now if it is for a slide in range where the unit would damage the flex connector, yeah. But a valve under a cook top, etc. would be pretty safe.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #6 (permalink)
Old 07-18-2007, 08:41 PM
Richard Rushing's Avatar
Same as Jim... I have never called it as In need of repair.
RR
Richard Rushing, HCRI
Duncanville, Tx.
  #7 (permalink)
Old 07-19-2007, 07:28 AM
Bob Harper's Avatar
damage?
The IFGC Commentary mentions that shutoffs located outdoors are more prone to damage than those indoors. I don't think they expect to see crash bollards or a steel cage surrounding them.
I agree I'd be more concerned with flex, esp. if there are large loops from using one too long.
Bob
Similar Threads
Don't open that valve! Joe Griffin Plumbing System: Home Inspection and Commercial Inspection 8 07-16-2007 05:18 PM
Secondary drain overflow shut-off M Kelekci Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-13-2007 08:03 PM
Gas shut off valve location Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 07-03-2007 10:53 PM
WAGS Valve? Rick Hurst Plumbing System: Home Inspection and Commercial Inspection 7 04-28-2007 05:10 PM
Water heater valve Gregg Austensen Plumbing System: Home Inspection and Commercial Inspection 9 04-24-2007 09:06 PM
vB.Sponsors
Ad Management by RedTyger
