Old 07-20-2007, 01:38 PM
dan orourke dan orourke is offline
Plumbing routing in crawlspace
Old 07-20-2007, 01:57 PM
Brian E Kelly Brian E Kelly is offline
Re: Plumbing routing in crawlspace
That was what is called thumb gum. It is usually used where a/c lines go into the house. It is probably used for expansion and contraction of the pipe. That copper is soft copper and not sure it is k-copper which it should be.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Similar Threads
air handler in crawlspace wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 06-19-2007 08:54 AM
Ground in crawlspace Jeff Eastman Sub-Structure: Home Inspection and Commercial Inspection 27 06-13-2007 05:46 PM
Electrical cable routing Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 2 06-05-2007 09:39 PM
Crawlspace vent fan Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 05-18-2007 09:13 PM
condensate drain routing Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-16-2007 08:49 PM
vB.Sponsors
Ad Management by RedTyger
