Old 07-20-2007, 04:08 PM
Dave Hahn Dave Hahn is offline
Flexible gas connectors
Does anyone know of a code/manufacturer requirement that a flexible gas connector be "looped" before connection to the appliance??
My gut says yes (as I'm seeing it often in newer installs, but I've recently seen an installation (new construction) where it wasn't.
I don't see anything under 2006 ICC FGC Section 411, and haven't been able to find any online manufacturer intallation instructions.
Thanks,
Dave
Old 07-20-2007, 04:25 PM
Re: Flexible gas connectors
Quote:
Not that I am aware of.
Old 07-20-2007, 06:21 PM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
There is none. That's why some are made as short as 2". The loops are simply because someone didn't want to make a trip back with the correct length so the loop was the easy way to deal with it. As long as they meet the min. bend radius (golf ball) they should be ok. Still, I try not to incorporaet dips and sags because they could act as a trap. I've actually seen one with a water seal.
BTW with long lengths on moveable appliances such as stoves and dryers, you need to form loops to make it coil out of sight yet allow room to pull the unit out.
HTH.
Bob
Old 07-20-2007, 08:40 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
Drip leg or sediment traps are often required or recommended by the manu., but never installed around here.
Old 07-21-2007, 07:30 AM
Bob Harper's Avatar
Martin, sediment traps are required by the code but might not be enforced locally. Still required..
Bob
Home inspection
Similar Threads
Flexible gas pipe Frank Bombardiere Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 07-20-2007 06:15 PM
vB.Sponsors
Ad Management by RedTyger
