Old 07-22-2007, 09:30 PM
neal lewis neal lewis is offline
Copper Gas line
First time I've run into sweated copper tubing for gas. Usually it's with a flare fitting.
I thought I read recently that this is not allowed. (Couldn't find the thread.)
Old 07-23-2007, 09:00 AM
Eric Shuman Eric Shuman is offline
Re: Copper Gas line
Neal,
Copper pipe for natural gas lines may or not be allowed in your jurisdiction, depending upon the amount of sulphur contained in the gas which can corrode the copper. It is not allowed wher I am in central Texas.
If I understand correctly, brazed fittings are allowed (but once again you should check with the local building authority to see if it is allowed) as long as the brazing material used has a melting point in excess of 1000F degrees and does not contain more than .05% phosphorus. (and as long as the copper is allowed in your area.) I am basing this on the 2003 IRC.
Eric
Old 07-23-2007, 09:28 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
Re: Copper Gas line
Neal,
That appears to be plumbing copper pipe and fittings, probably not approved for any type of gas usage.
I'd call it out.
Copper pipe is never sweated/soldered with gas. It is brazed, or mechanical connections, if local code allows.
A specific type of copper tubing is allowed under certain circumstances by the AHJ for natural gas. I've seen brazed copper before but it's not a nationally recognized method of joining gas pipe but could be locally. Compression fittings are no good for gas too prone to leaking. Flare fittings are good under certain circumstances.
The best way to go IMHO is rigid iron pipe with pipe dope. If you ever see Teflon tape it is not approved for gas unless it's yellow. White tape is not for gas.
I'd call this out also.
Residential-Commercial-Construction-EIFS-Infrared Thermography
Old 07-23-2007, 09:53 AM
M Kelekci M Kelekci is offline
Re: Copper Gas line
Quote:
Originally Posted by BARRY ADAIR View Post
Neal,
I'd call it out.
What was the give away? What are the major differences between plumbing copper pipe and gas line copper pipe?
Sometimes, I am seeing copper lines tapping in where the gas meter is to feed exterior gas fixtures ( lights, BBQ Grill etc). Do you all write this up?
How can you tell if the gas copper pipe is soldered or brazed?
Thanks,
Matt Kelekci
Houston TX
Old 07-23-2007, 09:58 AM
Re: Copper Gas line
Neal,
That is good advice from Barry. I should have mentioned that I would still call it out as a repair as it is true that it is not common (at least on any houses I have inspected) to use any copper fittings like the ones shown.
Eric
  #6 (permalink)
Old 07-23-2007, 10:54 AM
Re: Copper Gas line
Thanks,
All the copper gas tubing that I've seen is labeled and roll material not rigid like plumbing pipe in the pic.
Fuel Gas: Specifying Copper Tube
Yes, if not protected from impact damage, which it usually isn't.
Braze as a general rule is not rough and puddled (unwiped) as depicted.
Most of what I've seen and done has been brass color.
Similar Threads
copper wire Thom Walker Electrical Systems: Home Inspection and Commercial Inspection 2 06-29-2007 07:03 PM
Stranded copper at neutral bar wayne soper Electrical Systems: Home Inspection and Commercial Inspection 10 06-20-2007 06:02 AM
Tin coated copper question Bruce King Electrical Systems: Home Inspection and Commercial Inspection 5 06-19-2007 06:07 AM
Plastic uninion at copper line Eric Shuman Plumbing System: Home Inspection and Commercial Inspection 9 05-05-2007 09:04 PM
Copper Gas Line - RobertSmith Plumbing System: Home Inspection and Commercial Inspection 12 04-12-2007 12:03 PM
vB.Sponsors
Ad Management by RedTyger
