Old 07-23-2007, 09:12 PM
Terry Beck Terry Beck is offline
Water heater supply lines
Two questions. First, this material looks familiar but I can't place what it is called and its normal use. Black nylon braided coating, over what feels like stainless steel wound flex piping. Is this allowed material for water heater hot and cold supply lines? Can anyone give me a brand name of the material?
Second (same house), where I normally see flexible copper piping is as the water supply lines for the water heater has now been used as a convenient work-around for a properly installed copper pipe with elbows. It is obviously allowed for water heaters - my question, is this technically allowable by most code standards for normal supply pipe runs?
Home inspection
Old 07-25-2007, 10:50 AM
Frank Kunselman Frank Kunselman is offline
Re: Water heater supply lines
Yep, all three pieces are part of a 'Brasscraft" water heater connection kit...I've got one in my truck I'd like to return but can't find who carries them here. Anyway, whoever installed the three pieces didn't understand that the flex line was the gas supply connector...has a tapered end to fit the flared seat in the brass fitting, which reduces the size to 3/8" at the connection.
Remove the 'Br' and youv'e got the idea of the workmanship
Old 07-25-2007, 11:16 PM
I found it. It IS Brasscraft, and it IS certified for water heater supply lines.
http://www.brasscraft.com/pdf/0303_G...or_Catalog.pdf pg 27.
Funny how things run in cycles. Now today I found another flex water line on a water heater but it doesn't seem to appear on Brasscrafts's web site. So off we go again; what a way to waste a day.
Old 07-26-2007, 06:03 AM
Correction of previous post: The copper flex is ok if the piece has the dilectric sleeve and washer. For gas, it does not...hope he used the right one.
Old 07-26-2007, 05:33 PM
Jerry McCarthy's Avatar
Terry
Did you catch the lack of electrical bonding jumpers?
Construction Consultant
  #6 (permalink)
Old 07-26-2007, 05:58 PM
Scott Patterson's Avatar
I noticed a RED TAG on top of the water heater. By chance did you happen to take a look at it? They can be very enlightening at times!
Scott Patterson
  #7 (permalink)
Old 07-26-2007, 06:17 PM
Richard Rushing's Avatar
Is that a galvanized supply line?
Richard Rushing, HCRI
Duncanville, Tx.
Similar Threads
Water Heater Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 5 07-23-2007 06:31 PM
Water supply lines in attic dan orourke Plumbing System: Home Inspection and Commercial Inspection 1 07-14-2007 06:57 PM
Who's Water Heater is This Shane Pouch Plumbing System: Home Inspection and Commercial Inspection 3 05-11-2007 08:06 PM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 09:56 AM
Water heater Question Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-12-2007 04:29 PM
vB.Sponsors
Ad Management by RedTyger
