Old 07-30-2007, 02:36 PM
Fritz Kelly Fritz Kelly is online now
Rubber clean out caps
Are these type of caps OK to install at a clean out? Seems to me they should have screw in plugs.
Old 07-30-2007, 05:05 PM
Re: Rubber clean out caps
They should have screw in plugs, then again, you would want the clean out to be *above* the trap and pipe which may get clogged - otherwise, you will have a real big mess on your hands ... and in the cabinet ... and the floor ... and ...
Similar Threads
Window flashing caps Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 4 05-20-2007 05:28 PM
vB.Sponsors
Ad Management by RedTyger
