08-31-2011, 03:20 PM #1
Corrosion from electrolysis, repair item?
Came across corrosion at the galvanized copper junction at the hot water heater. I explained to the buyer and agents that this is called electrolysis due to dissimilar metals and was installed improperly as dielectric fittings should have been utilized. The listing agent came over and said this is not leaking, not a repairable item. I stated the galvanized fitting is defective due to the corrosion and recommended investigation by a licensed plumbing contractor or a qualified tradesperson. What are your thoughts.
08-31-2011, 03:33 PM #2
Re: Corrosion from electrolysis, repair item?
08-31-2011, 04:19 PM #3
Personally I would have reported it as a repair by a licenced plumber, it doesn't need further investigation.
Perhaps the listing agent has dissimilar metals for a brain.
Raymond Wand Home Inspection Service
http://www.raymondwand.ca
The value of experience is not in seeing much, but in seeing wisely.
08-31-2011, 04:39 PM #4
It is leaking ... see that river of rust down the side of it? That is from a leak ... and when rust seals the leak, it is still leaking (no repair has yet been made and the rust will give away, then eventually reseal itself again, and repeat the process until it finally rusts out and cannot seal itself).
08-31-2011, 06:38 PM #5
LinkBack URL
About LinkBacks
