02-10-2012, 07:39 AM #1
Galvanized "strap" around steel gas pipe
Will electrolysis occur between these metals.
02-10-2012, 08:14 AM #2
Re: Galvanized "strap" around steel gas pipe
Any time dissimilar metals are in contact they may have a galvanic reaction, however I think it unlikely for this to be a problem here.
Galvanic corrosion - Wikipedia, the free encyclopedia
Goto
Preventing galvanic corrosion
02-10-2012, 10:28 AM #3
I don't remember my chemistry, but I would say probably not. The underlying metal of the strap is steel. Zinc is used to coat steel pipe.
CREIA CCI & Evil Genius
02-10-2012, 12:46 PM #4
Wasn't galvanized plumbers tape designed to hold up steel pipes?
02-10-2012, 04:23 PM #5
Looks like steel pipe with steel straps, in which case, no, no galvanic corrosion.
LinkBack URL
About LinkBacks
