10-16-2007, 08:27 PM
BASEMENT PUMP USED for WASHER MACHINE
I came across this today and just wanted to get some feedback on how to report it?
ROBERT "JACQUES" MOUNTAIN
DREAM HOME INSPECTIONS
FAYETTEVILLE,GA
10-16-2007, 08:47 PM
Re: BASEMENT PUMP USED for WASHER MACHINE
Robert,
Improperly wired dryer connection.
Improper Washer drain.
Improper Dryer Exhaust.
Evidence of water intrusion on left side of basement window and on right side crack.
I'd start with that
Buy the way Robert is the Blue Bird School Bus manufacturing facility still next to The Roper Range Assembly Plant?
Billy J. Stephens HI Service
Reason: changed washer to dryer connection
10-16-2007, 08:56 PM
Thanks Billy,
I appreciate the quick response.
FAYETTEVILLE,GA
10-17-2007, 05:28 AM
Billy,
I don't see where the dryer would be improperly wired and is that a sump pump?
Mr. Davidson
10-17-2007, 05:43 AM
Originally Posted by Mr. Davidson
Billy,
Mr. Davidson,
If you click on the 2nd picture and zoom in . That squiggle line going to the outlet looks like
Romex draped across the wall and split before entering.
Sure looks like a sump to me.
10-17-2007, 05:54 AM
Billy,
So what type and size of wiring should have been used?
Mr. Davidson
10-17-2007, 06:04 AM
Billy,
Mr> Davidson,
The type and size is not the issue. The wiring method is. As you have stated in other post
you are new to HI please call out the electrician and learn some basic electrical.
10-17-2007, 06:16 AM
Please forgive my ignorance, I just want to be better prepared for the next go round.
Mr. Davidson
10-17-2007, 06:48 AM
Based on the water staining running across the basement floor, I'd say that the sump pump clothes washer drain system is inadequate for the the use (it's a sump pump, not a clothes washer drain pump) and that a proper clothes washer drain system needs to be installed.
A clothes washer can dump out 20-30-40 gallons of water QUICKLY, I doubt that setup can keep up with it, hence the water running across the floor.
Don't forget about that plastic dryer vent - not allowed.
Oh, yeah, and that can holding up the trap for the clothes washer standpipe? Priceless.
10-17-2007, 06:53 AM
Mr. Davidson,
We all have to learn and it's an on going process.
If your are unprepared to inspect some ones home you are doing them and yourself a disservice.
Some of the issues we check are life and limb concerns.
I would not want to be responsible someones death or disablement for lack preparation.
10-17-2007, 06:56 AM
Mr. Peck,
That's to catch the FEW dribbles that Leak from the trap.
10-19-2007, 09:14 AM
Robert : I saw some wild thing this one for the books I show you a picture of a walk-in cooler in a basement of a commerical business ranks up there too
http://thumbp2.mail.re4.yahoo.com/tn...=514&fid=Inbox
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Air in Well Pump line |
Jim Gecz |
6 |
08-30-2007 07:46 PM |
| Washer on GFCI |
dan orourke |
9 |
07-18-2007 08:23 PM |
| Washer / Dryer Closet |
Jeff Eastman |
8 |
07-15-2007 10:56 AM |
| Basement egress |
Mike Huppi |
Building Interior: Home Inspection and Commercial Inspection |
6 |
06-08-2007 08:49 PM |
| Insulate basement |
Mike Schulz |
Sub-Structure: Home Inspection and Commercial Inspection |
3 |
05-04-2007 10:25 AM |
