Old 10-19-2007, 07:37 AM
Dave Gilstrap Dave Gilstrap is offline
Vent termination
Can anyone tell me how high the plumbing vents should terminate above a flat roof in snow country? I have not inspected the home yet so I can't say yet how high they are, and the IRC book doesn't give a definate answer. P3103.1 Roof extensions
Old 10-19-2007, 07:42 AM
Re: Vent termination
Quote:
Is that a good idea?
You need to check with your local AHJ.
6" is the minimum height above a roof, then the AHJ adds to that so the vent will be above snow height - at least the AHJ *should* add to that.
Old 10-19-2007, 09:13 AM
brian schmitt brian schmitt is offline
dave,
906.7 calif. plumb. code frost or snow closure "vent terminals shall be a minimum of two inches in diameter but in no event smaller than the required vent pipe.. thechange in diameter shall be made inside the building at least one foot below the roof in an insulated space and terminate not less than 10 inchesabove the roof ,or as required by the ahj.
Similar Threads
Plumbing vent termination Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 14 07-17-2008 06:11 PM
Plastic power vent to metal vent at brick chimney Christopher Kovac Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 24 10-09-2007 02:30 PM
Could not locate dryer vent termination M Kelekci Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 09-23-2007 07:48 AM
Catch pan drain termination Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 11 04-30-2007 03:19 PM
High Efficiency Flue Termination Sean Bacon Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-03-2007 04:24 PM
vB.Sponsors
Ad Management by RedTyger
