Old 10-19-2007, 11:20 AM
Clay White Clay White is offline
WH vent to draft hood connection
Old 10-19-2007, 12:28 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: WH vent to draft hood connection
Quote:
Originally Posted by Clay White View Post
I just can't put my finger on it, but the wh vent to draft hood connection looks wrong, or am i crazy? Is there a problem?
(note: insulation clearances are wrong, I know!)
Clay,
The first section of vent pipe is a 90 degree elbow that has been straightened out.
Looks funny,Sloppy, Lazy but no problem I know of it's rated vent.
Where is the water cut off for wh?
Billy J. Stephens HI Service
Old 10-19-2007, 05:09 PM
Kevin Barre Kevin Barre is offline
Quote:
Originally Posted by Billy Stephens View Post
Clay,
Right there on the inlet to the right opposite the flue. Where the break in the insulation is.
Old 10-19-2007, 06:05 PM
wayne soper's Avatar
The draft hood has a tapered end for a reason, right. That is so you can shove that sucker right down snug and screw it togeather. Neither of which they got right.
Old 10-19-2007, 06:07 PM
John Arnold John Arnold is online now
Needs a single-wall to b-vent adapter at the draft hood I do believe.
  #6 (permalink)
Old 10-19-2007, 09:00 PM
I can't see a problem based on this photo. So long as the inner liner of the flue sits properly on the diverter, it looks OK to me.
Home inspection
Similar Threads
Water Heater Vent Connection Bruce Breedlove Plumbing System: Home Inspection and Commercial Inspection 13 08-30-2007 03:42 PM
WH draft hood, insulation clearance Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 07-25-2007 01:48 PM
carbon build up at draft hood - furnace Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 07-21-2007 02:59 PM
Gas line for cook top routed through down draft vent allen elliott Plumbing System: Home Inspection and Commercial Inspection 2 06-01-2007 10:02 PM
insualation clearance from draft hood dan orourke Plumbing System: Home Inspection and Commercial Inspection 9 05-03-2007 07:24 PM
vB.Sponsors
Ad Management by RedTyger
