Old 10-23-2007, 02:56 PM
Chip O'Brian Chip O'Brian is offline
Leaking TPR Valve
Had a plumber tell me that dripping is normal at discharge pipe for TPR valve. Any thoughts, opions. I have done a couple inspections this is a first.
Chip
Destin,Fl
"The only non-addressable objection is the unkown"
Home inspection
Old 10-23-2007, 03:02 PM
John Arnold John Arnold is online now
Re: Leaking TPR Valve
Wrong. It's leaking for a reason. Either the pressure in the tank is too high, or the valve is defective, or the valve won't seat properly due to corrosion or whatever. Needs fixin', dang it.
Old 10-23-2007, 03:18 PM
Rick Hurst's Avatar
He's probably the one who replaced it, so he's feeding you a line.
It could possibly lead to wood decay on that wood siding which should not be below the pavers.
Old 10-23-2007, 03:47 PM
fritzkelly fritzkelly is offline
"Had a plumber tell me that dripping is normal at discharge pipe for TPR valve"
If thats true, then 95 percent of the ones I see are defective.
Old 10-23-2007, 03:58 PM
Scott Patterson's Avatar
Quote:
As others have said, it is not normal. If the home has a pressure regulator or back flow preventer and it does not have an expansion discharge valve or an expansion tank this is why it is leaking. Also high water pressure can cause them to leak.
Scott Patterson
  #6 (permalink)
Old 10-23-2007, 05:56 PM
Rick Cantrell Rick Cantrell is offline
Scott has the right idea.
I think it should read
It is normal (but not correct), if the home has a pressure regulator or back flow preventer and it does not have an expansion discharge valve or an expansion tank, this is why it is leaking.
Rick Cantrell
  #7 (permalink)
Old 10-23-2007, 06:04 PM
Quote:
This property does not appear to have either.
Chip
Destin,Fl
  #8 (permalink)
Old 10-23-2007, 06:24 PM
Chip
As the water heats up in the water heater it expands. A backflow preventer and pressure regulator stop the water from expanding back into the city water line, and the expanding water increases pressure, therefore an expansion tank is needed to allow the water a place to expand to and thus reduce pressure. If there is not an expansion tank, then the pressure will build up, the T&P valve will open to relive the pressure.
So either the T&P valve is leaking because it's bad, or it's leaking because there is not an expansion tank. Either way it should not be leaking.
Rick Cantrell
  #9 (permalink)
Old 10-23-2007, 07:09 PM
Does not even need a backflow valve or a pressure regulator, which is why the expansion tank is required (or, according to some plumbing inspectors, a pressure relief valve - I don't buy it, but I'm busy with the T&P drain discharge outlet first, then back to the thermal expansion tank issue).
You should be finding at least another pressure relief valve (besides the T&P). The T&P pressure relief is set to 150 psi, which is WAY TOO HIGH for the maximum allowed 80 psi, so the other pressure relief should be set to no higher than 80 psi (P2903.3.1 FRC), and this will 'leak' whenever the pressure gets too high (above 80 psi).
  #10 (permalink)
Old 10-23-2007, 07:40 PM
Jerry
I don't follow what your are saying.
"Does not even need a backflow valve or a pressure regulator, which is why the expansion tank is required (or, according to some plumbing inspectors, a pressure relief valve - I don't buy it, but I'm busy with the T&P drain discharge outlet first, then back to the thermal expansion tank issue)."
Rick Cantrell
  #11 (permalink)
Old 10-23-2007, 08:50 PM
Rick,
You don't need a pressure regulator or a backflow preventer valve to create enough pressure in the system to cause the T&P to leak. While it takes 150 psi to make them pop open (at least that's what they are set at maximum), they will 'leak' at a lower pressure.
That's all I was saying.
The rest was for Chip as he is in Florida and I was just stating that I'm trying to convince those-in-power that flooding the house when the T&P goes off serves no practical purpose - when the T&P goes off, it has passed through its danger zone and gone into the safety zone, just like it would do when draining to the exterior - like was done for decades. Meaning, I'm not beating people over the head about thermal expansion tanks yet.
Similar Threads
Faulty TP valve Dan Harris Plumbing System: Home Inspection and Commercial Inspection 40 11-02-2007 06:47 AM
Valve attached to PR valve on H20 HEATER brian Beach Plumbing System: Home Inspection and Commercial Inspection 21 10-30-2007 06:47 PM
Valve in Firebox ? Bob Sisson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 25 08-27-2007 11:20 PM
Leaking window william siegel Building Envelope: Home Inspection and Commercial Inspection 5 04-10-2007 09:02 PM
vB.Sponsors
Ad Management by RedTyger
