Old 10-25-2007, 06:50 PM
Richard Roshak Richard Roshak is offline
Green and Black Copper Piping
These photo's are from a 2 year old home. Home has a basement, poured concrete foundation, no signs of water penetration, no chemicals stored in basement and owner keeps humidity level around 55%. Any idea what the cause is?
Rich
Home inspection
Old 10-25-2007, 07:17 PM
Re: Green and Black Copper Piping
Excessive condensation on cold water pipes?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 10-25-2007, 08:00 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Richard,
Is this home close to salt water and the basement cross ventilated ?
Billy J. Stephens HI Service
Old 10-25-2007, 08:05 PM
The green is on both hot and cold piping.
No, we are not near the ocean.
Old 10-25-2007, 08:09 PM
wayne soper's Avatar
That is some kind of chemical reaction. That is not common condensation or corrosion from common elements. How long have they been in the home. And how long has it been like this. Need more info
  #6 (permalink)
Old 10-25-2007, 09:09 PM
Quote:
Rich
Quote:
Richard,
(site search corrosion)
From what you describe and some of the photos the copper pipe could be corroding from the inside out. Copper Development Association - www.copper.org - Info on copper and its alloys.
  #7 (permalink)
Old 10-25-2007, 09:40 PM
That is not from the inside out. That is something that splattered or condensed on the pipe surface.
  #8 (permalink)
Old 10-25-2007, 10:05 PM
Wayne,
Thats what I was thinking. Just going by Richards statements and photos.
1. Not evidence of staining of over spray on surrounding surfaces.
2. No over flux pattern.
3. Most signs of corrosion appear on bottom of water lines that have a downward bow.
  #9 (permalink)
Old 10-25-2007, 10:49 PM
Jon Randolph Jon Randolph is offline
By looking at the engineered joists, it appears that you may be right next to the center supporting block wall in the basement. Could it be muriatic acid from someone trying to clean up after a sloppy mason after the fact?
What is that (black) to the left in your 2nd pic? It also has the pattern on it.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #10 (permalink)
Old 10-26-2007, 05:49 AM
These pipes are in the center of the basement, I did inspect this home prior to closing and this green was not there. I inspected the home yesterday for the owners two year warranty.
  #11 (permalink)
Old 10-26-2007, 12:42 PM
Bill Wieczorek Bill Wieczorek is offline
I have that on my copper pipe coming out of the hot water tank. The house is 30 years old so you can be sure its not a big problem. I agree its likely something the plumber did to clean up the pipe. My water is fine and so are the pipes.
  #12 (permalink)
Old 10-27-2007, 10:47 AM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
Did you look to see if any on the copper pipes were in contact with the galvanized (forced air) ducts or any galvanized metal? This situation could cause the corrision shown in your photos. My only other suggestion/thought might be aggressive water.
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
  #13 (permalink)
Old 10-27-2007, 05:13 PM
Rick Hurst's Avatar
I have read also that high levels of sulphur and chloride in water can cause such corrosion.
  #14 (permalink)
Old 10-27-2007, 05:43 PM
Are they storing any swimming pool chemicals under the pipes?
  #15 (permalink)
Old 10-27-2007, 05:48 PM
Wayne,
It's a stumper Ain"t It!!
  #16 (permalink)
Old 10-28-2007, 11:54 AM
Martin Baker Martin Baker is offline
Rich
Richard was this corrosion in a centralized location or throughout the system?
Martin
  #17 (permalink)
Old 10-29-2007, 12:25 PM
Martin,
All exposed piping in the basement was this color.
Rich
  #18 (permalink)
Old 10-29-2007, 06:08 PM
OK " Broker appears to have passed gas in the basement area causing caustic discoloration and damage to copper water lines." That was easy!
  #19 (permalink)
Old 10-29-2007, 06:28 PM
Quote:
Originally Posted by Rick Hurst View Post
I have read also that high levels of sulphur and chloride in water can cause such corrosion. rick
Rick
I was leaning toward something in the water source also.
I did a blowup of picture # 4 and saw a shiny piece of cooper pipe where black scale was
removed.
At this point Wayne's reason sounds as good as any.
( unless something corrosive had been stored and has been removed)
