Old 11-15-2007, 05:17 PM
Water Heater Vent
Home inspection
Old 11-15-2007, 07:24 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Water Heater Vent
What I would concentrate on is that the bottom vent section slips OVER the section above it - it should be inserted INSIDE the section above it.
Eric Barker
Barrington, IL
Old 11-15-2007, 11:47 PM
Russel Ray Russel Ray is offline
I'm not seeing what you're seeing, Eric.
Old 11-16-2007, 06:41 AM
Does this help?
Eric Barker
Barrington, IL
Old 11-16-2007, 07:29 AM
Stuart Brooks's Avatar
Stuart Brooks Stuart Brooks is offline
Looks like an "unusual" installation to me. From what I can see in the picture, I would most likely recommend that a qualified-licensed-professional plumber correct it as soon as possible.
Thats polite speak for, "it looks like a total whacked-up, jack-leg, amateur installation that could cause your family to not wake-up one morning".
That is, in my most humble opinion, which I admit in advance will conflict with someone else's.
Stu
  #6 (permalink)
Old 11-16-2007, 07:39 AM
Michael Greenwalt's Avatar
Michael Greenwalt Michael Greenwalt is offline
Could be my eyes but that single wall vent appears to be closer than 6 inches to the wall before it terminates into the B-vent.
If I had two faces, would I be wearing this one?
Abraham Lincoln
  #7 (permalink)
Old 11-16-2007, 07:54 AM
Hey, Eric.
What your arrows are point to looks like the demarcation where the flue diameter decreases just slightly so that it will fit into the piece above it. What I've marked looks to me like the one above it is definitely over the one below it, as indicated by where the screws are and the bend in the metal.
This is a very good reason why I rarely comment on pictures. The flat dimension, angle, lighting, etc., can lead to false conclusions.
  #8 (permalink)
Old 11-16-2007, 08:23 AM
Ray,
Pardon my analness (it drives my wife crazy). The flue is the space inside the liner. What we're talking about is the vent connector (or chimney connector as the case may be). BTW - I'm still trying to get away from saying outlet and instead say receptacle.
Anyway, I'm quite sure that the picture is clear enough to say that the connection at my arrow is wrong - the bottom vent is slipped over the vent section that's between our two arrows.
I attached a picture which relates. The stains show where combustions gas has been escaping from the improper connection.
Does this help??
Eric Barker
Barrington, IL
  #9 (permalink)
Old 11-16-2007, 09:30 AM
If that little two-inch section is, indeed, a section, then, yes, it is wrong. It just doesn't look that way to me in the picture. To me it looks like part of the section below our arrows.
  #10 (permalink)
Old 11-16-2007, 04:11 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
Russel,
Looking at the rolled joint in the inserted piece and the screw at the right top of the piece below it. It's on the inside of connecting vents.
Billy J. Stephens HI Service
  #11 (permalink)
Old 11-16-2007, 06:59 PM
Quote:
Originally Posted by Billy Stephens View Post
Russel,
Looking at the rolled joint ...
At first I thought you were going to say something quite different than what you talked about.
  #12 (permalink)
Old 11-16-2007, 07:17 PM
Quote:
What? Me?
Home inspection
Similar Threads
Water Heater Vent Connection Bruce Breedlove Plumbing System: Home Inspection and Commercial Inspection 13 08-30-2007 03:42 PM
Water HEater Vent Clay E White Plumbing System: Home Inspection and Commercial Inspection 3 08-21-2007 01:29 PM
Water heater vent pipe wayne soper Plumbing System: Home Inspection and Commercial Inspection 3 07-25-2007 06:46 PM
Who's Water Heater is This Shane Pouch Plumbing System: Home Inspection and Commercial Inspection 3 05-11-2007 08:06 PM
Upsized water heater vent pipe Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 2 04-30-2007 11:32 AM
vB.Sponsors
Ad Management by RedTyger
