Old 12-03-2007, 05:10 PM
Sheryl Davidson Sheryl Davidson is offline
HELP! =)
Hey guys! I had this water heater in a home I looked at this weekend and I not sure about the age, although I am for sure it is OLD! It is a Rheem Fury and on the plate, the serial number starts with 0562. Does that mean May 1962? Or were the numbers done differently then as compared to today? Thanks!
Home inspection
Old 12-03-2007, 05:18 PM
Scott Patterson's Avatar
Re: HELP! =)
I would say that dates back to the early to mid 1980's based on the design. Looking at the data plate I would put the date at 1987, if I'm reading it right.
I don't bother with dates all that much, I use it for my information only and I do not report it. If I can tell a unit is old or if it needs attention, as this unit does I report it as such.
IMO, if a WH is over 10-12 years of age it has lived a good life and replacement will be soon.
Scott Patterson
Old 12-03-2007, 05:37 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Re: HELP! =)
May of '62 as best I can tell. Haven't seen stamped metal plate on a water heater for a very long time.
How about the lack of a drip/dirt leg on the gas line?
Where is the TPR and associated piping?
Notice a missing access door as well.
Old 12-03-2007, 05:52 PM
Re: HELP! =)
Yeah, I noticed all the problems with it. Here is a picture of what I think may be the relief valve, which I have not seen before. Can someone clarify this? The potential homeowner has already said she wants to have it replaced ASAP. I just wanted to make sure I write the correct age on my report so that I don't look like a ding dong with the plate picture. Thanks!
Last edited by Sheryl Davidson : 12-03-2007 at 05:55 PM. Reason: Forgot to add photo
Old 12-03-2007, 06:33 PM
Re: HELP! =)
that's an adjustable pressure relief valve but cant tell if it responds to temp as well. Either way it's wrong.
The water is heater is well past it's average design life and needs to be replaced by a qualified plumber.
  #6 (permalink)
Old 12-03-2007, 06:36 PM
James Duffin James Duffin is offline
Re: HELP! =)
It appears that the relief valve is mounted on the water heater outlet. If the relief valve has a long temperature stem on it and the BTU rating is correct then the setup is most likely OK. The stem length should be on the relief valve tag. If the heater is piped properly and is working properly it does not need to be replaced until it fails. I would advise the client that it is past it's normal expected life but is not in need of immediate repair.
  #7 (permalink)
Old 12-03-2007, 06:45 PM
Re: HELP! =)
When it;s that old I tell my client to budget for replacement. To put any money into this installation would be a waste. IMHO.
  #8 (permalink)
Old 12-03-2007, 06:51 PM
Re: HELP! =)
Thanks guys! The homeowner is wanting to change over to electric so she is already making plans to change it out. I couldn't believe how well the water heater was working when I inspected. It makes you wonder why products these days can't be made this well.
  #9 (permalink)
Old 12-03-2007, 06:59 PM
Re: HELP! =)
I'm also going to go with May of 1962.
I think those metal labels went out in the 60s or 70s.
Also, the T&P looks to date back to then.
  #10 (permalink)
Old 12-03-2007, 07:16 PM
fritzkelly fritzkelly is offline
Re: HELP! =)
That needs to go in the 'oldest operational water heater' contest.
vB.Sponsors
Ad Management by RedTyger
