Old 12-05-2007, 12:51 PM
Jim Zborowski Jim Zborowski is offline
pipe fitting
ok, just trying out the picture download here. Anyone ever see one of these, never saw a fitting specifically to jog arround another pipe.
Old 12-05-2007, 05:35 PM
Rick Hurst's Avatar
Re: pipe fitting
Jim,
Never seen one of those myself before.
You sure you didn't photoshop that one?
Old 12-05-2007, 05:52 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: pipe fitting
Jim,
There's some severe Rust on the Tee and vertical pipe sections behind that Goose Neck.
The one in the fore ground looks painted ( to hide rust?) hidden rust scales? It's getting them bumps from somewhere.
Billy J. Stephens HI Service
Old 12-05-2007, 06:28 PM
wayne soper's Avatar
Re: pipe fitting
There is one proud patent holder behind that one. Somewhere in poland!
Old 12-06-2007, 07:28 AM
neal lewis neal lewis is offline
Re: pipe fitting
Seen loads of 'em in houses with galvanized water pipes. Always used to jog around the other pipe.
  #6 (permalink)
Old 12-06-2007, 10:08 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Re: pipe fitting
They are still available HERE
  #7 (permalink)
Old 12-07-2007, 05:45 PM
Randy Aldering Randy Aldering is offline
Re: pipe fitting
Those and many others. It is surprising to see what efforts were made to make mechanical installations neat and clean in the past. Another lost behavioral trait. The metal support on the CPVC line in the background is a NO-NO.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
  #8 (permalink)
Old 12-07-2007, 06:04 PM
Re: pipe fitting
Quote:
Why?
Metal straps are used, and approved for use, on CPVC fire sprinkler piping.
  #9 (permalink)
Old 01-29-2008, 03:10 PM
Re: pipe fitting
Think about that for a minute: how often are sprinkler pipes used? How often are CPVC sprinkler pipes going to be used?
All piping, regardless of the material, expands and contracts during use, due to both temperature and pressure changes. This expansion and contraction produces movement of the pipe. With plastic pipe, this movement is more pronounced. So, when plastic pipe moves back and forth, like a saw, on a metal pipe hanger, what do you suppose is going to happen, eventually?
www.housesmithe.com
  #10 (permalink)
Old 01-29-2008, 08:20 PM
Re: pipe fitting
"The metal support on the CPVC line in the background is a NO-NO."
"Think about that for a minute:" where is your supporting documentation to the "NO-NO" part?
Code?
Manufacturer's installation instructions?
What / where?
  #11 (permalink)
Old 01-29-2008, 10:15 PM
Matt Fellman Matt Fellman is online now
Re: pipe fitting
Isn't the bracket in question for use with electrical conduit?
I've never seen one of those in the plumbing isle at the hardware store....
Similar Threads
multiple NM cables entering panel enclosure through one fitting Jerry Peck Electrical Systems: Home Inspection and Commercial Inspection 1 12-03-2007 04:00 PM
PVC flue reduction fitting Don Murphy Introductions By New Members 5 09-30-2007 07:46 AM
Conduit to fitting connection John Stephenson Electrical Systems: Home Inspection and Commercial Inspection 2 06-22-2007 06:35 PM
Fitting on JB John Stephenson Electrical Systems: Home Inspection and Commercial Inspection 5 05-29-2007 10:53 AM
What is this fitting? Jim Robinson Plumbing System: Home Inspection and Commercial Inspection 7 05-08-2007 08:55 PM
vB.Sponsors
Ad Management by RedTyger
