Re: Tankless water heater comment
Micheal,
Thank you very much for sharing what sounds like some hard learned information. Well done!
I am seeing more of these units, from some rather old cheap AquaStars (reconditioned models on eBay sell for $350) to the newer models. I really appreciate your comments about gas line sizing and improper installations. A lot of my inspections are rural properties built by "custom home builders" (stress the word custom), with little or no code inspections, many are on well water (which has many of its issues with water pressure and high mineral content), some on propane, and being in Montana we also have to contend with freezing temperatures. As a side note, one enterprising home owner replaced an old tankless gas boiler that supplied heat for hot water baseboard heat with a Rinnai on-demand water heater; seemed to work pretty well in a rather small house.
I have noticed sizeable fluctations in water temperture even on supposedly properly installed systems. Do you have any further information or thoughts about some of Chris's original comments? I've run into some info both of the below issues, but my info was pretty thin.
"There are flow restrictors so only the set water temp will leave the unit. If you set the water temp higher then there will be less water output.
And ---
"Service is needed to clean --I believe it is one of the sensors, from mineral buildup/scale. Or maybe it's the small filter screen."
Thanks again.
