Old 04-12-2007, 04:48 PM
Scott Patterson's Avatar
Check those CSST connections
I found this today on a warranty inspection. The CSST was too short for the application, it had been kinked and it was also not protected. To top it off it was starting to pull out of the fitting.
Scott Patterson
Old 04-12-2007, 06:06 PM
Re: Check those CSST connections
Scott,
When are you going to quit kinking gas lines and stuff ... just so you can write them up?
Old 04-12-2007, 08:58 PM
dick whitfield
Posts: n/a
I would have fixed it and checked for leaks.....N/C!
Old 04-12-2007, 09:19 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
Liability, liability, liability
And after you leave, what happens if...............
Old 04-13-2007, 12:02 PM
Bob Harper's Avatar
Not CSST
What was pictured is technically a "flexible applance connector" listed to ANSI Z21.24. The basic application here is acceptable to the flex mfr. as long as it is not exposed where it could be expected to get damaged. It depends on what is going on to the side of that WH where the folding chair is. Personally, I would have run 1/2" CSST from the shutoff to the sediment trap/ valve.
Similar Threads
CSST Class Action Settlements??? Shane Pouch Plumbing System: Home Inspection and Commercial Inspection 9 04-04-2007 12:06 PM
Time stamp and spell check Kevin Luce H E L P ! 4 04-01-2007 06:33 PM
vB.Sponsors
Ad Management by RedTyger
