Old 12-23-2007, 06:38 PM
JD Johnson JD Johnson is offline
Are sink shut-off valves required?
Hello all and Merry Christmas - I have a quick question about a new construction home I recently inspected. NONE of the bathroom sinks had shut-off valves, so I plan to include this as an Informational item on my report, but could not find any documentation in the Florida Building Code that these are actually a required device. Can someone let me know if shut-off valves are actually required under a building code?
If shut-off valves are required, I can make a stronger statement, encouraging the installation of these devices - so any documentation you can site would be appreciated.
Thanks much and have a safe holiday season
JD Johnson
Beach To Bayou Property Inspections
Old 12-23-2007, 06:43 PM
Re: Are sink shut-off valves required?
I can't speak on the Florida requirements, but was this house plumbed with PEX? Sometimes there is a master manifold with shutoffs that would fulfill any requirments of a shutoff.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 12-23-2007, 06:52 PM
The house was copper, as much as I could see...and I could find no PEX manifold.
JD Johnson
Old 12-23-2007, 06:54 PM
John Goad John Goad is offline
2003 IRC P2903.9.3
An individual shutoff valve shall be required on the fixture supply pipe to each plumbing fixture other than bathtubs & showers.
If it is a PEX system with manifold the valves should be labeled with the fixture served.
Clarksville Home Inspection
JW Goad
Old 12-23-2007, 07:25 PM
Quote:
From the 2004 Florida Residential Code.
- P2903.9.3 Valve requirements.
- - Valves serving individual fixtures, appliances, risers and branches shall be provided with access. An individual shutoff valve shall be required on the fixture supply pipe to each plumbing fixture other than bathtubs and showers.
Read the above first for which fixtures are required 'to have' valves, the below states 'where' those valves may be located.
- P2903.8.6 Valving.
- - Fixture valves, when installed, shall be located either at the fixture or at the manifold. If valves are installed at the manifold, they shall be labeled indicating the fixture served.
  #6 (permalink)
Old 12-23-2007, 08:03 PM
Thanks y'all -
JD Johnson
  #7 (permalink)
Old 12-24-2007, 06:31 AM
Jerry - thanks, I am travelling and don't have my Code books handy, and was trying to use the online version, but I was searching the FBC and FBC Plumbing - NOT FRC! Thanks again, and y'all have a Merry Christmas!
JD Johnson
Home inspection
Similar Threads
Gas Turn-key Valves for Fireplaces Clay White Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 18 11-01-2007 07:43 PM
gas shut off valve Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 6 07-19-2007 07:28 AM
Secondary drain overflow shut-off M Kelekci Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 07-13-2007 08:03 PM
Gas shut off valve location Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 07-03-2007 10:53 PM
Sweeping Required? Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 06-12-2007 05:01 PM
vB.Sponsors
Ad Management by RedTyger
