Old 04-13-2007, 10:12 PM
Plumbing vent termination
Old 04-13-2007, 10:24 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Re: Plumbing vent termination
A PVC cap on the lateral would be a reasonable solution at this point in my opinion.
The sweep of the "T" might encourage some moisture to accumulate in the horizontal portion of the pipe; but I would think that would not be a major issue in consideration of the fact that the vent in general is already going to be moisture laden and somewhat "stinky" if you will.
What's the big deal about a bit of stagnant water in a sewer vent environment anyway?
Other's will, no doubt, disagree.
Old 04-13-2007, 11:01 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
At least from the picture, the moisture and rain should dribble down the back side of the vent since it looks like the pipe is on a slant. Or is it the photo?
Old 04-14-2007, 11:18 AM
Needs that fitting removed.
Least one day the owner awakens to a leak caused from the water which will collect in that terminated fitting.
Old 04-14-2007, 11:28 AM
"Needs that fitting removed."
Admittedly, the best solution.
  #6 (permalink)
Old 04-14-2007, 01:41 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is online now
Cut pipe, put straight coupling.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
  #7 (permalink)
Old 04-14-2007, 02:27 PM
Quote:
Make that two couplings and a short section of pipe.
If you cut that fitting out and install one coupling, the pipe will now be too short to properly penetrate through, and above, the roof.
  #8 (permalink)
Old 04-14-2007, 07:03 PM
I stand corrected again. Did not think it all the way through. But if that pipe is extended 2' above the roof it would be brought down to the proper height and only need one coupling.
  #9 (permalink)
Old 04-14-2007, 08:08 PM
UNLESS ... that 2 feet height was required locally for snow load or for other reasons.
Ya never know ...
  #10 (permalink)
Old 04-14-2007, 11:35 PM
Maybe its the angle of the photo, but isn't that pipe on an angle going through the roof?
Shouldn't that penetrate the roof more or less level (up and down) reason being, the angle of that pipe going through the roof is a little odd for the lead boot that is going over it isn't it?
Pipe looks to me like it is following the angle of the roof instead of being straigh up and down.
Is this a problem?
  #11 (permalink)
Old 04-15-2007, 08:57 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
For me, I'd leave the decision up to a licensed plumber.
Eric Barker
Barrington, IL
  #12 (permalink)
Old 07-17-2008, 03:06 PM
Terry Scroggin's Avatar
Terry Scroggin Terry Scroggin is offline
I found this interesting item today. It is the house sewer vent for a septic system in a very small town. The house is over 100 years old and the drain system in the house works like a charm. The house only has 1 bathroom so I had all faucets on (including the tub) and then flushed expecting an overload. Suprise!!! No problem, even adding the kitchen drain.
I don't think it would pass any kind of a code, but how should it be written up?
My only beef with it is its location during the winter for snow buildup as it is only a few inches off the ground.
By the way, there aren't any openings within 10 feet in any direction and I didn't smell it at all during the inspection.
  #13 (permalink)
Old 07-17-2008, 06:35 PM
Looks like a frsh air intake to me.........but what do I know, you saw it, how did you determine it was a sewer vent?
  #14 (permalink)
Old 07-17-2008, 06:59 PM
"Assumed" because there is no other vent on the roof or in the attic for the septic tank. It could be a fresh air inlet because the septic system is a new style aerated system, but I'm not a septic system expert. I just have one of those systems outside my dining room window. Maybe I will return and cover that vent then go inside and check the drains.
  #15 (permalink)
Old 07-17-2008, 07:11 PM
Just listen at the pipe while the drains are in use. It should be pretty easy to confirm this is the vent. Most of what a vent does is an air "inlet" but I don't know of a way to make this a one way vent
The aerobic systems use a pump, not an open vent.
If it is a old house, you are probably right assuming it is the main vent and it is wrong.
It may not provide much odor if there is a belly or fitting in the line creating a trap.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Home inspection
Similar Threads
Plumbing configuration RobertSmith Plumbing System: Home Inspection and Commercial Inspection 4 04-07-2007 10:30 AM
Plumbing Addition gone bad!! Sean Bacon Plumbing System: Home Inspection and Commercial Inspection 8 04-06-2007 02:00 PM
Reverse plumbing to water heater Terry Beck Plumbing System: Home Inspection and Commercial Inspection 7 04-06-2007 05:54 AM
High Efficiency Flue Termination Sean Bacon Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-03-2007 05:24 PM
10,219 Archived Plumbing System Posts Brian Hannigan Plumbing System: Home Inspection and Commercial Inspection 0 03-21-2007 01:27 AM
vB.Sponsors
Ad Management by RedTyger
