01-09-2008, 01:48 PM
Interesting P Traps
I am always amused by the plumbing I find under kitchen sinks.
01-09-2008, 02:21 PM
Re: Interesting P Traps
Those are outstanding.
01-09-2008, 02:24 PM
I'm partial to the trombone one myself.
01-09-2008, 02:26 PM
Nice trap on the first one, it really doesn't matter if the trap is on it's side, it'll still work.
01-09-2008, 02:32 PM
Lee,
Not following you there.
A trap must be vertical.
Or did I miss the smiley face you intended?
01-12-2008, 04:46 PM
The first one is a new "Z" trap!
01-12-2008, 05:23 PM
Then there's the "trap-not" or, "I don't have to show you no stinkin traps!"
01-12-2008, 06:15 PM
And the shop-vac trap...
01-12-2008, 06:56 PM
Jerry Mc.,
Made with radiator hoses no less!
Wonder what they are trying to 'radiate'?
01-12-2008, 06:58 PM
Dom,
Oh the ingenuity of the American People, no wonder we are so far along as a developing nation ...
01-13-2008, 12:16 PM
Yeah, I forgot my smiley, I was just being sarcastic.
01-14-2008, 11:27 AM
Red neck ingineeering at is finest.
Great stuff,
//Rick
01-14-2008, 11:33 AM
You don't need a trap when you're just running the utility tub drain straight into your basement water control system.  Let the sump pump take care of it.
01-14-2008, 12:41 PM
While likely an Approved Installation for much of the State of PA, I would Not Agree.
01-14-2008, 07:01 PM
What would concern me more is the exposed splices in second picture.
01-25-2008, 07:18 AM
Not a material common in my area, any issues when you "mix-and-match" like this?
01-25-2008, 07:22 AM
Not an issue with mixing different materials, but that drain installed with that tee like it is, the disposer is going to try to pump water back up into the sink before it ever thinks of going down, and, water from the sink, if drained rapidly, could readily back up into the disposer before it goes down the bottom leg of the tee.
That tee should have been installed with the inlet/outlet on the vertical, with the disposer (or the sink) entering on the side inlet.
01-25-2008, 07:43 AM
Yup... that dishwasher will try and back-up the sink almost every time. That set-up is a like having a crystal ball-- easy to tell the future.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
01-25-2008, 07:52 AM
Then there is this pretty little beauty (drum) I just found under a home two days ago. Kinda gets you all happy under the home when you see one of these because they are just too far between sightings...
Rich
Duncanville, Tx.
01-25-2008, 03:54 PM
Rich
Seen about once a week around old New England.
Dave
