Re: Low water flow at fixtures
John,
You can remove the handle by removing the hex screw on the bottom.
Then you'll see a small screw head on the end of the cartridge. Turn the brass piece by hand to the hot side. You can tap on the end of the screw lightly and it will shake free the sediment on it which is prevent it to open properly.
