Old 01-14-2008, 01:14 PM
Jerome W. Young Jerome W. Young is offline
small supply lines
I noticed weak water flow at the kitchen sink and found the flexible supply lines from the shut off are smaller than 3/8 in. Is there a minimum requirement for a kitchen?
Home inspection
Old 01-14-2008, 02:43 PM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
Re: small supply lines
Jerome,
Low flow could have also been a result of a partially clogged screen (on the faucet), however lines are typcially 3/8". I would write it up as low flow and recommend further evaluation by a plumber.
Robert Dalga
Home Analysts
Kalamazoo, MI
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
Old 01-14-2008, 05:17 PM
Tommy Moorehead Tommy Moorehead is offline
Does the faucet start out strong and then go weak? If it does, you probably have a restriction in the main supply line. Place a pressure guage on the laundry hook-up, check the pressure. Now turn on another faucet and watch the pressure fall. Shut off that faucet and see how long it takes for the pressure to come back up. If it's slow, it's a restriction. I would start at the main valve or pressure regulator , if it's got one. (ok, let the plumber decide)
If it's slow all the time and other faucets in the home aren't check the aerator screen or there is "crap" (technical term) in the valve/head. We have very hard water out here in AZ. The aerator screens plug up frequently.
Good Luck with the Water Gods
Home inspection
Similar Threads
Small business briefs - MiamiHerald.com Brian Hannigan Business Operations: Home Inspectors & Commercial Inspectors 0 09-26-2007 08:11 PM
Water heater supply lines Terry Beck Plumbing System: Home Inspection and Commercial Inspection 6 07-26-2007 06:17 PM
Water supply lines in attic dan orourke Plumbing System: Home Inspection and Commercial Inspection 1 07-14-2007 06:57 PM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 09:56 AM
Taking Care of 'Small' Business: LIFE Foundation Offers Five ... - PR Newswire (press Brian Hannigan Business Operations: Home Inspectors & Commercial Inspectors 0 03-26-2007 06:40 PM
vB.Sponsors
Ad Management by RedTyger
