Old 04-15-2007, 07:58 AM
PVC water supply lines in crawlspace
Old 04-15-2007, 08:46 AM
Re: PVC water supply lines in crawlspace
From the IRC.
- P2904.5 Water-distribution pipe.
Water-distribution piping within dwelling units shall conform to NSF 61 and shall conform to one of the standards listed in Table P2904.5.
- TABLE P2904.5
- - WATER DISTRIBUTION PIPE
- - - (PVC is not shown on the Table as an allowable material)
- P2904.4 Water service pipe.
Water service pipe shall conform to NSF 61 and shall conform to one of the standards listed in Table P2904.4.
- TABLE P2904.4
- - WATER SERVICE PIPE
- - - Polyvinyl chloride (PVC) plastic pipe
The code reference, then, is "PVC is not allowed for use as distribution piping according to P2904.4 and Table P2904.5, IRC."
Old 04-15-2007, 08:52 AM
Brian E Kelly Brian E Kelly is offline
Jerry may be right as to the code, but in NY the code also states that local law can over ride State and or National code. We have a large amount of CPVC piping and even some PVC piping that is labeled as use with potable water. That pipe in NY would not last one winter.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Old 04-15-2007, 08:56 AM
Quote:
*CPVC* is okay for use as supply/distribution piping.
It's the *PVC* that is not.
However, PVC *is* rated for use for potable water, which is why it is allowed outside for the water service pipe.
Are you sure that *PVC* is allowed for supply/distribution piping inside?
Home inspection
Similar Threads
Ground in crawlspace Jeff Eastman Sub-Structure: Home Inspection and Commercial Inspection 27 06-13-2007 04:46 PM
Crawlspace vent fan Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 05-18-2007 08:13 PM
4,994 Archived Foundation, Crawlspace Posts Brian Hannigan Sub-Structure: Home Inspection and Commercial Inspection 0 03-21-2007 12:38 AM
vB.Sponsors
Ad Management by RedTyger
