LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-15-2007, 04:37 PM
rust on gas meter
Home inspection
Old 04-15-2007, 05:18 PM
John Arnold John Arnold is offline
Re: rust on gas meter
From what I can see in the photo, I wouldn't be that concerned about rust - but what is that flex line going into the ground? If it's CSST, why isn't the outer covering on it at the top?
Old 04-15-2007, 11:14 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
John,
Can not tell for sure from the photo, but that does not look like flex pipe going into the ground to me.
It looks like some kind of wrap maybe at the top or rigid to flex maybe but the pipe going into the ground looks to me to be rigid.
Old 04-16-2007, 08:20 AM
Scott Patterson's Avatar
That is the supply line from the gas utility. I don't think it is CSST. That "rib" looking at the top is most likely a covering on the line and the location wire that is wrapped around the gas lines so that the line can be located.
Rust like that on a meter would not even make my report.
Scott Patterson
Old 04-16-2007, 12:46 PM
Jeff Gainey's Avatar
Jeff Gainey Jeff Gainey is offline
I don't comment on any surface rust seen. I will comment on any meter that the base is buried in the ground or mulch for possible corrosion issues. See this a lot, mostly mulch.
Home inspection
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/plumbing-system-home-inspection-commercial-inspection/547-rust-gas-meter.html
Posted By For Type Date
this on the townhouse next door to the one I was inspecting. This thread Refback 04-19-2007 10:17 AM
Similar Threads
Gas meter David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 04-13-2007 04:37 PM
vB.Sponsors
Ad Management by RedTyger
