01-26-2008, 08:39 AM
Is PB the only Black line?
I found this yesterday... 2005 home with a black service line. My understanding is that Polybutelene lines are susceptible to leakage and have been involved in litigation. Question is... is PB the only possibility and is my previous statement true?
01-26-2008, 09:13 AM
Re: Is PB the only Black line?
PB is typically gray (although I think they may have made service lines in blue - not sure). Black is typically ABS.
01-26-2008, 09:28 AM
This is a water service line, not waste. Is ABS used for service? I've never seen that?
01-26-2008, 09:48 AM
More information ... albeit for DWV usage.
ABS Products
Cheers - Nolan E. Kienitz, HCRI, PMP
ICC Certified Residential Plumbing Inspector (P-1)
www.NolansInspections.com
01-26-2008, 10:32 AM
My guess (and it's only that) is that the black service line is a form of polyethylene.
And, yes, they did make blue polybutylene service lines. They were used pretty extensively around here. The rocks tend to cut 'em up pretty badly, leading to leaks.
01-26-2008, 12:09 PM
2006 IRC, Table P2904.4, Water Service Pipe, does list ABS as suitable for use as "water service pipe", however, Table P2904.5, Water Distribution Pipe, does NOT list ABS as being allowed for "water distribution pipe".
Also: (bold and underlining are mine)
- P2904.4 Water service pipe. Water service pipe shall conform to NSF 61 and shall conform to one of the standards listed in Table P2904.4. Water service pipe or tubing, installed underground and outside of the structure, shall have a minimum working pressure rating of 160 pounds per square inch at 73°F (1103 kPa at 23°C). Where the water pressure exceeds 160 pounds per square inch (1103 kPa), piping material shall have a rated working pressure equal to or greater than the highest available pressure. Water service piping materials not third-party certified for water distribution shall terminate at or before the full open valve located at the entrance to the structure. Ductile iron water service piping shall be cement mortar lined in accordance with AWWA C104.
I.e., if the water service pipe is not also approved for water distribution pipe, it must terminate 'outside the structure' - and, if that is ABS in the photo, it does not.
01-26-2008, 12:59 PM
Seems to me unusual to find PB or polyethylene in a 2005 home. Is this a mobile?
The apostrophe troll.
01-26-2008, 02:35 PM
All of the black water service entrance pipes around here are made of polyethylene. It is still being used on new houses.
The polybutylene water service entrance pipes are blue and the polybutylene water supply pipes in houses are gray.
ABS has never been used for water supply pipes in my area. It is only used for drain lines.
01-26-2008, 05:13 PM
Folks, That's pipe insulation around an unknown pipe.
JLMathis
01-26-2008, 06:51 PM
Thanks JLMathis... essentially what I wrote up. I expect (hope) that it's PE and no it wasn't a mobile... S/F SBL. Thanks again for all the input!
01-26-2008, 07:01 PM
Jeffrey,
If you look above the white coupling, you will see that the pipe insulation is pulled away and the black tubing/pipe can be seen.
01-26-2008, 08:47 PM
JLMathis
Jeffery,
This BLACK PIPE (see attached photo).
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Green and Black Copper Piping |
Richard Roshak |
18 |
10-29-2007 06:28 PM |
| How To Do A Home Inspection - Black Enterprise |
Brian Hannigan |
Inspection News From Around The Net |
0 |
05-09-2007 06:20 PM |
| Black stuff on a wall. |
K Robertson |
Environmental, Pests, Health and Safety: Home Inspection and Commercial Inspection |
7 |
05-01-2007 03:18 PM |
| black flex gas line |
dan orourke |
12 |
04-18-2007 07:21 AM |
| Black marks on ceiling |
Brian E Kelly |
Attic Areas: Home Inspection and Commercial Inspection |
8 |
04-15-2007 06:55 PM |
