Old 01-30-2008, 06:22 AM
Jerome W. Young Jerome W. Young is offline
proper supply piping/ air gap at dishwasher
is this burst resistant hose ok to use in this application? this heater is under a kitchen counter.
yes it needs a tpr pipe
Anyone know any reason why this should not have an sir gap or high loop? the drain line comes from the bottom of the dishwasher and directly to the disposal
Old 01-30-2008, 07:05 AM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: proper supply piping/ air gap at dishwasher
Jerome,
1. I'd say no on the flex line.(See AO Smith attachment)
2.NO! on the dishwasher unless you like disposal water circulating in your dishwasher.
Billy J. Stephens HI Service
Old 01-30-2008, 07:59 AM
I agree with Billy ... with some hesitation on the dishwasher high loop - because the dishwasher could - COULD - *COULD* - but might not , have a built in high loop.
I always wrote them up and let a plumber verify that it either had one or they install one.
Also, no clamp at the disposer connection and that dishwasher drain hose could come off, making a real mess real fast.
Also sure that you caught the missing plate at the receptacle back there.
I know you said the T&P needs a relief line, but consider 'how' it is going to be added ...
Old 01-30-2008, 09:23 AM
i dont know on the pipe may cpvc will make it possible. either way I made a note of it and they canfigure it out
Old 01-30-2008, 10:20 AM
Richard Rushing's Avatar
Also, at a minimum, the hot water side supply line of the water heater should be insulated.
It can't be visually identified by the photo, but since that sucker is inside the home, it needs a drain pan-- was one present?
RR
Richard Rushing, HCRI
Duncanville, Tx.
  #6 (permalink)
Old 01-30-2008, 11:33 AM
yes a pan was present believe it or not.
Thanks All
Home inspection
Similar Threads
CTSX Piping Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 9 12-28-2007 11:32 AM
galvanized piping Scott Lynch Plumbing System: Home Inspection and Commercial Inspection 5 07-22-2007 07:36 PM
Dishwasher Inspection Rick Hurst Built-In Appliances and Systems: Home Inspection and Commercial Inspection 22 06-29-2007 04:14 AM
Dishwasher David Banks Plumbing System: Home Inspection and Commercial Inspection 3 05-21-2007 07:51 PM
GE dishwasher recall John Arnold Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 05-16-2007 04:55 PM
vB.Sponsors
Ad Management by RedTyger
