Old 02-13-2008, 11:30 AM
Aaron Miller Aaron Miller is offline
Senior Member
TPRs Leaking
This one's got me and I need help. New house, two new gas water heaters. There is a pressure regulator on the system. There is also an expansion tank on the system. The TPR valves leaked. They have been replaced twice now and still leak. What's the problem?
Thanks,
Aaron
Old 02-13-2008, 11:54 AM
Michael Larson's Avatar
Michael Larson Michael Larson is offline
Re: TPRs Leaking
Quote:
Thanks,
Aaron
Sorry all I have is more questions:
1. What's the temperature setting of the water heaters?
2. Is the expansion tank properly sized, installed and charged?
3. Is the regulator installed and adjusted correctly?
Old 02-13-2008, 11:57 AM
Senior Member
Re: TPRs Leaking
119°
Yes.
I think so.
Aaron
Old 02-13-2008, 12:02 PM
Re: TPRs Leaking
Thanks,
Aaron
At a minimum you would have to know what the pressure is in the system.
I suppose it's possible to have bad TPRs but not likely.
The expansion tank could be water logged and rendered ineffective.
If it were mine I would put a pressure gage on the tank drain valve and monitor while the heater is cycling.
One other thought. Is the mineral content high in the water? Accumulation of Calcium deposits can cause the TPR to stick.
Old 02-13-2008, 12:05 PM
Senior Member
Re: TPRs Leaking
Michael:
I will do just that.
Thanks,
Aaron
  #6 (permalink)
Old 02-13-2008, 12:13 PM
Richard Rushing's Avatar
Re: TPRs Leaking
I believe it is one of two things...
1) The thermostat is not working properlty (causing overheating conditions) or
2) Stacking Temperature is probably happening. The "stacking-temperature" conditon takes place when the home users frequently/often use small damands of hot water. This keeps the thermostat cool enough to run the burners longer than needed.
The result is that the cold water entering the tank cannot absorb the diret heat output (down by the burner). The result is that the water surrounding the heated surfaces picks up more heat all the way to the top-- stacking the temperature while creating a fair amount of pressure along the way.
One other question for your... since there is a possibility of frequent short use of hot water, is the home inhabited by a large family? Is there "any" possibility that the toilets could be cross plumbed to provide hot water into the water closet tank? If so, that could be a source of 'frequent' quick use of hot water use.
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #7 (permalink)
Old 02-13-2008, 12:14 PM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
Re: TPRs Leaking
I'd bet Michael's right about that.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
  #8 (permalink)
Old 02-13-2008, 12:32 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: TPRs Leaking
Double check to make sure that the valves are TPR and not just relief valves. A RV will go off over 30 PSI, while a TPR should be at least 75 PSI. Just a thought.
  #9 (permalink)
Old 02-13-2008, 04:23 PM
Re: TPRs Leaking
Quote:
I agree with Chad, I think Michael has it right.
*IF* the expansion tanks were working properly, they should be able to handle the thermo-expansion, if there is anything wrong with them (water logged, deflated, low pressure, high pressure, whatever) then they will not work 'well', they might work 'somewhat', but maybe not enough.
  #10 (permalink)
Old 02-13-2008, 04:48 PM
Senior Member
Re: TPRs Leaking
Thanks to everyone for their replies. When I get to the bottom of this I'll let you know where it all went wrong.
Aaron
Home inspection
Similar Threads
Leaking TPR Valve Chip O'Brian Plumbing System: Home Inspection and Commercial Inspection 10 10-23-2007 08:50 PM
Leaking window william siegel Building Envelope: Home Inspection and Commercial Inspection 5 04-10-2007 09:02 PM
vB.Sponsors
Ad Management by RedTyger
