Old 02-13-2008, 03:03 PM
Jerome W. Young Jerome W. Young is offline
thermal expansion/ closed water system
A.O. smith recommends xpansion tanks on a closed water systems. i had a condo this am and the plumber installed a new heater yesterday. no xpansion tank or device was installed that i could see. Is a condo a "closed water system" and or do they had relief at a common area anywhere?
Old 02-13-2008, 03:20 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: thermal expansion/ closed water system
Jerome your question is a little hard to decipher and your spelling is horrific
I'm going to give it a shot:
A municipal water system is a (closed water system) and it is under
pressure. That is how the water is delivered to you home. Since the
pressure is greater than atmospheric, when you open the faucet, the
water flows.
But one can argue the wording because for water to flow it has to draw air from somewhere which typically is the vent on top of a water tower.
In our area you have to take out a permit for water heaters and install it to todays code which includes expansion tanks. I'm not sure about electric water heaters though?
Not sure what you mean by this (and or do they had relief at a common area anywhere?)
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Old 02-13-2008, 03:29 PM
I was abbreviating, although not that brief for expansion. I know that is not how you spell it. Other than that, I dont see any spelling errors. Thanks for the input.
Old 02-13-2008, 03:30 PM
yeah the grammar was bad too. I was in a hurry damn it.
Old 02-13-2008, 04:18 PM
  #6 (permalink)
Old 02-13-2008, 04:27 PM
A condo building will typically have a closed water system, which requires a 'pressure relief device', which could be just a 'pressure relief valve', which, of course, brings up the question as to 'where in tarnation are you going to dump the pressure relief discharge to? Unless there is a pan under the water heater, and the water heater will not be setting in water, and ... and ...
  #7 (permalink)
Old 02-14-2008, 04:48 AM
Thanks, What would be an example or alternative to a closed water system?
  #8 (permalink)
Old 02-14-2008, 05:51 AM
A standard single family home with NO check valve or pressure reducing valve at the meter would be an example of an open system. The water pressure can bleed back into the city water main (ever see the small movement triangle "rock" back and forth when all the water is off in the house?) Any check valve or regulator that impedes the flow of water back to the main makes it a closed system since water can only flow into the system.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Home inspection
Similar Threads
New Infrared Thermal Imaging (ITI) Message Board Kevin Richardson Inspection News From Around The Net 3 07-21-2008 11:16 PM
Wood fired hot water system Jack Feldmann Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 03-19-2008 04:56 AM
Thermal Imaging Video John McKenna General Chit Chat: Home Inspectors & Commercial Inspectors 1 12-23-2007 07:19 AM
Business Expansion. David Banks Business Operations: Home Inspectors & Commercial Inspectors 8 08-10-2007 06:02 AM
Thermal training presentation Richard Stanley Tools and Equipment 0 07-04-2007 11:00 AM
vB.Sponsors
Ad Management by RedTyger
