LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-18-2007, 05:55 AM
PVC drain lines
Home inspection
Old 04-18-2007, 06:23 AM
Re: PVC drain lines
Quote:
Originally Posted by Jeff Eastman View Post
Can PVC drain lines be on the ground/dirt in the crawlspace or do they have to be suspended above the ground. The lot has a great slope in front to back so the plumber just layed the drain with the natural slope of the yard to the city connection.
They need to be properly "supported" and "secured".
Sounds like they have the "supported" part down. If the line was buried, then it would also be "secured".
Are you in a freeze area? If so, it needs to be protected against freezing too.
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/plumbing-system-home-inspection-commercial-inspection/583-pvc-drain-lines.html
Posted By For Type Date
this supply piping material in a mobile home built This thread Refback 04-19-2007 09:15 AM
Similar Threads
Secondary drain setup Jeff Gainey Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-17-2007 10:10 PM
lead drain John Arnold Plumbing System: Home Inspection and Commercial Inspection 5 04-17-2007 03:18 PM
condensate drain routing Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 04-16-2007 07:49 PM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 08:56 AM
condensate drain connection dan orourke Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 04-12-2007 08:19 PM
vB.Sponsors
Ad Management by RedTyger
