Old 02-15-2008, 05:41 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
Handyman Special
Had a house today that was a "Class A" Home Handyman special. Image reflects a bar sink drain (yes, I know there is no P-trap ... let me finish). The drain includes the flexible product that is okay for "home handyman temp" use and the horizontal line goes through the wall and connects (about 4') to the drain in the adjacent bath sink at the appropriate location above the P-trap. Slope is okay all the way.
Picture a kitchen dual-sink drain where one drain stem comes down and then routes horizontally to the adjacent sink drain stem & P-trap.
With that thought in mine I have two questions:
1) Would you approve the current arrangement going from the bar sink to the bath sink?
2) Would you approve the flexible connection?
I'm afraid I'll be writing for a while on this report. It was a pre-listing inspection. Most of the modifications were done by the prior owner from what I understand. AND ... current owner is an agent.
Gonna be interesting to say the least.
Cheers - Nolan E. Kienitz, HCRI, PMP
ICC Certified Residential Plumbing Inspector (P-1)
www.NolansInspections.com
Old 02-15-2008, 05:56 PM
Re: Handyman Special
Quote:
Originally Posted by Nolan Kienitz View Post
The drain includes the curly-que product that is okay for "temp" use ...
"okay for "temp" use "??? Says who?
It is not okay for any use in a drain.
Quote:
With that thought ...
2) Would you approve the curly-que?
1) Absolutely not.
2) Absolutely not.
Old 02-15-2008, 05:59 PM
Jerry P.,
Tnx much. Just the validation I needed to lock in what I was keying in the report.
Old 02-15-2008, 06:35 PM
Patrick Martinez Patrick Martinez is offline
Nolan,
only if the drain in an indirect waste and dumping into a tapped floor drain or other trapped fixture can this be done. If the drain is connected to another fixture trap this is not permitted as each fixture requires its own trap.
As to the curly Q, ABSOLUTELY NOT!
Good luck
Pat
Old 02-15-2008, 06:57 PM
Nick Ostrowski Nick Ostrowski is offline
"Improper and unprofessional installation of trap and corrugated drain line on wet bar sink - repairs needed by a professional plumber"
Those corrugated drain lines shouldn't be manufactured or sold. I can't think of one plumbing application where their installation is acceptable.
  #6 (permalink)
Old 02-15-2008, 07:25 PM
Nolan,
Quote:
Pat has it right.
The reason your two compartment kitchen sink example did not play is that it is a "single" fixture, which only requires 'one trap'.
What you described were "two" fixtures trying to share that 'one trap'.
And, then (of course) the interior of a drain line or fitting is required to be smooth (so it does not collect debris and waste, least it: a) clog up; b) promote the growth of bacteria).
Now, *IF* the trap arms were the correct size and the trap arms did not exceed their maximum allowable length, one solution (*IF* those *IFs* worked out okay) would be to install a trap under the bar sink, tie it into the branch arm between the bathroom sink trap and the stack.
Even if it were a little off on the above *IFs*, it would still work much better than what is there, not that you could give it your blessing, but you could 'degrade it less'.
  #7 (permalink)
Old 02-15-2008, 08:20 PM
Tony Mount Tony Mount is offline
Nolan, Be careful who you listen to on this board, #1 You are not a code inspector, so if a system is preforming its function you can NOT call it out for repair. #2 The home owner does NOT have to bring things up to code if it is cosmedic in nature.#3 the pipe used will not clog or smell any more than a dirty lever stopper in a sink. #4 have Jerry prove the pipe can not be used by a home owner or that the manufacture does not approve it for that use. #5 you can NOT predict what might happen to that pipe and how long it will last. Now the P-Trap is a different story.
  #8 (permalink)
Old 02-15-2008, 09:51 PM
Richard Rushing's Avatar
#1--- What??? The hell you can't. You damn sure better if you know something is wrong. If you don't know it's wrong... go back to changing oil til you get the proper education.
#2--- What???? Of course not, if it's cosmetic in nature. Nothing Nolan posted falls under that category though...
#3--- What????? Anyone who does not identify the corrigated pipe used as an improper use of materials shouldn't be inspecting for a living... sheesh!!
#4--- (What the plumbers use) Uniform Plumbing Code section 701.2 states, "Drainage fittings shall be of cast iron, malleable iron, lead, brass, copper, ABS, PVC, vitrified clay, or other approved materials having a smooth interior waterway of the same diameter as the piping served..."
#5--- See 1, 2, 3, & 4 above.... No need to predict the future. The future is the present.
This is a joke right
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #9 (permalink)
Old 02-15-2008, 09:59 PM
Rick Hurst's Avatar
Richard,
None of those rules abide to the Tony Mount SOP's.
  #10 (permalink)
Old 02-15-2008, 10:38 PM
Quote:
I'm intrigued.... So, it's not okay for temp use and not for permenant use.... So, what is the purpose of this slinky-like plastic matter that is for sale in every hardware store in the country?
Or, am I mis-understanding the sarcasm here?
Don't get me wrong, I know these things are junk and have no place in a house.... but they are sold for a purpose. I guess my question is, what is the purpose?
  #11 (permalink)
Old 02-15-2008, 11:13 PM
Okay, here are some excerpts...
Ch 3 2006 UPC 301.1.1
All Pipe, pipe fittings, traps, fixtures, material and devices used in a plumbing system shall be listed or labeled, (3rd party certified), by a listing agency, (accredited conformity assessment body) and shall conform to approved applicable recognized standards referenced in this code, and shall be free from defects. All materials, fixtures, or devices used or entered into the construction of plumbing systems, or parts thereof, shall be submitted to the AHJ for approval.
Ch 10 2006 UPC, 1001. Each plumbing fixture excepting those having integral traps.
1001.2 One trap may serve not more than 3 single compartment sinks or laundry tubs of the same depth or 3 lavatories immediately adjacent to each other and in the same room if the waste outlets are not more than 30 inches apart and the trap is centrally located when the three compartments are installed.
Nolan, I don't think anyone here is trying to be too verbose but only conveying an understanding of code requirements. If it is questionable, you did the right thing to post it here to gather some understanding from the other inspectors. Hopefully this helps in your endeavors also.
Taker care and good luck.
Pat
  #12 (permalink)
Old 02-15-2008, 11:50 PM
Rick Hurst's Avatar
Matt,
The purpose is too make the almighty dollar. Plain and simple.
  #13 (permalink)
Old 02-16-2008, 07:55 AM
Eric Shuman Eric Shuman is offline
What Rick said, plus,
Many items that are not approved and listed for specific uses (such as the corrugated pipe) can and are sold because they offer an easy way out of something that may be harder or costlier to repair. Where there's a market, there's a product, even if it is not allowed or approved!
Kinda like using a can of fix-a-flat in your flat tire. Not recommended or a proper repair and it is flat-out (pardon the pun) dangerous to the tire installer but sometimes effective and a lot cheaper and faster than taking your wheel off and into the shop!
Eric
  #14 (permalink)
Old 02-16-2008, 10:22 AM
Rick Hurst's Avatar
not a handyman!
  #15 (permalink)
Old 02-16-2008, 11:37 AM
Matthew Barnicle Matthew Barnicle is offline
This is an obvious writeup. "Undersink plumbing installed in amateur / non-workmanlike manner. Among the deficiencies are corrugated/temporary type drain pipe, lack of proper trap, lack of accessible water shutoffs to undersink water supply and unsealed/open pipe to wall penetrations. Recommend review and repair as needed by licensed plumbing contractor" Then you can tell the client verbally (if you want) that if he doesn't get it fixed, he might get some odors from the corrugated pipe or have to plunge it from time to time, etc. etc.
  #16 (permalink)
Old 02-16-2008, 04:23 PM
Nolan, There is a differance between Required Repair and potential problem with a system. One must be repaired because of dangerous reasons, damaged, not performing its intended function. The other is somthing that IS preforming its function, may not be up to code, and should be noted in the report. However if the system IS PREFORMING ITS FUCTION you are lible if you state the system is NOT up to CODE, Unless you are a liscensed plumber.
  #17 (permalink)
Old 02-16-2008, 05:39 PM
(underlining is mine)
Quote:
Tony,
I've watched and read as you have made that same transition many times before, stating one to create a higher standards, then stating the other to try to justify your low standard.
In reality, the first one is correct and should be used and applied in both instances: "its intended function"
Just like the information in your other post ... you have apparently no idea what you are talking about.
You probably like those corrugated flexible tail pieces as they can catch and trap diamonds and are easier to find and recover.
  #18 (permalink)
Old 02-16-2008, 05:54 PM
John Arnold John Arnold is online now
Jerry, please.
The smiley face does not stop the pain.
  #19 (permalink)
Old 02-16-2008, 06:11 PM
John,
Should I delete that line? The truth (by his own admission) can be painful at times.
What say you?
And others?
  #20 (permalink)
Old 02-16-2008, 06:16 PM
