Old 02-20-2008, 12:24 PM
Big Big Bubble under Manf Home
I always knew this was a possibility but this is the first time I ran across it. This is about a 5 year old manufactured home and something obviously didn't get hooked up right or has come loose.
I hope for the guy fixing it that it's not '#2' - eeesh what a mess!!
Old 02-20-2008, 02:11 PM
Dom D'Agostino Dom D'Agostino is offline
Re: Big Big Bubble under Manf Home
OK, what's a " #2 "?
Old 02-20-2008, 02:34 PM
Like when you ask your kids... do you have to go #1 or #2? I'm thinking if it's from the sink or shower it wouldn't be that bad.... from the toilet? Yikes...
Old 02-20-2008, 02:35 PM
Bruce Ramsey's Avatar
Bruce Ramsey Bruce Ramsey is offline
When you go to the bathroom you either do number 1 or number 2. He hopes this is not a sewer problem.
Bruce Ramsey
Advocate Inspections
www.NCAdvocate.com
Old 02-20-2008, 03:34 PM
Got it, thanks for the visual...
  #6 (permalink)
Old 02-20-2008, 05:22 PM
Rick Hurst's Avatar
The numbers 1 & 2 have been brought to you today by our friends at Sesame Street.
  #7 (permalink)
Old 02-20-2008, 06:11 PM
Jon Randolph Jon Randolph is offline
Quote:
Actually, it could be condensation above the vapor barrier, which is why it should not be installed at the bottom of the floor joists. I don't know why manufactured homes keep doing this.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #8 (permalink)
Old 02-20-2008, 06:50 PM
Brandon Whitmore Brandon Whitmore is offline
When I see something like that (although, not usually that extreme), I usually poke through with a screwdriver-----did you poke it
  #9 (permalink)
Old 02-20-2008, 07:29 PM
Quote:
I was totally tempted and usually do.... This was really huge though... If it burst there was no way I could get away without getting totally drenched, or covered, whatever the case may be.
The plastic was so strethed out it looked like it was on the verge... and then, as I'm laying there I'm realizing I just put a bunch more water in it by testing everything.
Similar Threads
Exterior Outlets, GFCI, Bubble Cover, Clay White Electrical Systems: Home Inspection and Commercial Inspection 4 11-05-2007 05:14 PM
Home, sweet home if you had a good inspector - TheNewsTribune.com Brian Hannigan Inspection News From Around The Net 0 11-01-2007 03:02 AM
YOUR PLACE TO CALL HOME: Is a home inspection worth the money? - Suburban Journals Brian Hannigan Inspection News From Around The Net 0 09-30-2007 04:27 PM
vB.Sponsors
Ad Management by RedTyger
