Old 02-24-2008, 11:52 AM
fritzkelly fritzkelly is online now
PVC Supply piping
Does anybody know if PVC was ever allowed for cold water supply piping in the house? The house was built in 1979.
Old 02-24-2008, 06:24 PM
Re: PVC Supply piping
Not to my knowledge.
It was 'not looked at closely enough' in many areas as the codes used to use one chart for both water service pipe and water distribution pipe, and one had to go through the additional step of looking at the referenced sections to determine what was allowed or not.
For example, the old Standard Plumbing code referenced Section P608, which only required "The minimum working pressure of plastic piping installed outside of the foundation walls shall be 160 psi (1103 kPa) at 73ºF (23ºC), with permanent identification markings." - which equals PVC, whereas water distribution piping referenced P611, which required "P611.1.1 Minimum working pressure for plastic hot and cold piping material shall be 100 psi (689.5 kPa) at 180ºF (82ºC)." - which equals CPVC.
If all you did was look at the table, PVC was listed in the table as suitable for use - you also needed to verify its 'suitability for WHAT use', which many did not think of doing.
Old 02-25-2008, 06:33 AM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
PVC piping for water supply (hot or cold) has been in use for years up here in MI. No problems if done right. You might start to see more of it cropping up with the price of Copper going thru the roof!
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
Old 02-25-2008, 06:47 AM
Quote:
Robert,
You mean "CPVC", not "PVC", right?
Old 02-26-2008, 07:04 AM
Yes (an No). PVC piping was used prior to the 80's, then CPVC.
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
  #6 (permalink)
Old 02-26-2008, 01:44 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Prior 1980 which maybe the codes wern't enforced Right?
I would suspect that from a town named Kalamazoo.........
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
proper supply piping/ air gap at dishwasher Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 5 01-30-2008 11:33 AM
CTSX Piping Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 9 12-28-2007 11:32 AM
A/c piping in electrical chase allen elliott Electrical Systems: Home Inspection and Commercial Inspection 3 08-22-2007 01:11 PM
galvanized piping Scott Lynch Plumbing System: Home Inspection and Commercial Inspection 5 07-22-2007 07:36 PM
Unknown piping. Eric Shuman Plumbing System: Home Inspection and Commercial Inspection 11 05-14-2007 08:09 PM
vB.Sponsors
Ad Management by RedTyger
