Old 02-27-2008, 04:07 PM
Jerome W. Young Jerome W. Young is offline
waste venting/bubbling toilet
I had a toilet today that was bubbling air through the trap almost splashing water out of the toilet when I started to drain the adjacent spa tub. both fixtures shared a waste vent. The tub had a 1.5 in. and it connected to a 3 in. that appeared to come from the toilet through the roof. I am not sure if the vent was blocked or what. Anyone know what is going on here?
Home inspection
Old 02-27-2008, 04:57 PM
Scott Patterson's Avatar
Re: waste venting/bubbling toilet
Quote:
Sounds like the vent might be blocked. Could be several other things as well.
What happened when you flushed the toilet? Did it bubble at the tub or could you hear water from the drain?
Scott Patterson
Old 02-27-2008, 06:00 PM
Could be a vent blockage or a waste line blockage.
The vent could be something as simple as the plumber left the test ball in it and it is still inflated, blocking the vent, or, they may not have removed the thin plastic test cap. I've seen both more times than one would think possible.
Or, the test cap could have been broken out and knocked into the waste line instead of being removed, allowing the pieces to catch on something and partially block the waste line. When that happens, a lot of water draining at once places a lot of pressure into the waste line, and that pressure could spurt back up (just like you described).
That would be my two first guesses.
Have a plumber run a camera down the vent stack from the roof, they will see exactly what is where, if anything is anywhere. If nothing is there, then they may need to run the camera from inside (because the blockage could be between the drain and the stack).
Old 02-27-2008, 08:01 PM
Rick Hurst's Avatar
If its not any of the issues JP mentioned it may be one of those toilet demons.
Look out now! as O.J. says.
Old 02-28-2008, 12:26 PM
Scott,
I did not test the toilet with the tub full.
Thanks All
Similar Threads
Oil Filter looking device in Waste line? Bruce Ramsey Plumbing System: Home Inspection and Commercial Inspection 9 10-31-2007 10:10 AM
in the toilet... Help Anthony Alderman Plumbing System: Home Inspection and Commercial Inspection 11 08-30-2007 02:44 PM
Drain Waste David Banks Plumbing System: Home Inspection and Commercial Inspection 6 08-16-2007 08:13 PM
Waste Connection Eric Smith Plumbing System: Home Inspection and Commercial Inspection 10 06-12-2007 06:49 PM
Indirect waste lines... Shane Pouch Plumbing System: Home Inspection and Commercial Inspection 4 05-24-2007 09:42 PM
vB.Sponsors
Ad Management by RedTyger
