Re: What is this?
It's a drum trap. It's common on old houses. Is that lead pipe on the drain lines? Believe it or not, I've never seen a lead pipe, since there aren't any in my area.
The drum trap should be removed, as it makes it very hard to snake a clogged drain line. The condensate drain should have an air gap, unless there is one farther upstream from its termination at the drum trap.
